ehime Posted May 27, 2011 Report Share Posted May 27, 2011 So I've heard about the horrors of 1970's wiring jobs, and stumbled across more than on user who has burnt their car down because of ~40yr old wiring. I had the idea today to possible create an entirely wiring setup for my wagon. I do not have blueprints, I do not have technical wiring experience, and I do not know what gauges or colors I should use to keep things segregated (You CAN buy multicolor wire, right?) Info would be appr so I don't kill myself and others. Thanks guys, -jd Quote Link to comment
banzai510(hainz) Posted May 27, 2011 Report Share Posted May 27, 2011 what wrong with the wiring now.??????? Clean it should be fine. Quote Link to comment
izzo Posted May 27, 2011 Report Share Posted May 27, 2011 I should have a PDF of the wiring diagram at home on my pc, PM me your email and ill check it out tonight when i get home. Quote Link to comment
zerow Posted May 27, 2011 Report Share Posted May 27, 2011 I'm running mine as-is. Stock wiring. The upgrades should be made at the ends...i.e. lights, fixtures, etc. Its those parts that are exposed to the elements, and not the wiring. I am meticulously cleaning each connector with contact cleaner and a little 320 grit sandpaper. I checked each wire for full continuity and against the ground for any shorts. Nothing found yet that warrants a complete re-wire... Just my 2 cents... Quote Link to comment
elmerfudpucker Posted June 2, 2011 Report Share Posted June 2, 2011 That is one of the reasons I went with a full LED conversion on the truck. Quote Link to comment
