chester Posted May 19, 2011 Report Share Posted May 19, 2011 So the l16 I bought it had a brand new cam in it and all I saw then was cwc and I-5 then yesterday I saw the end when I switched to my peanut head and at the end it had a hex head in the middle and had 685 stapped in it a one spot and the letter A in another. Any help would be great. Thank you Dan Quote Link to comment
Wide14u Posted May 19, 2011 Report Share Posted May 19, 2011 its just a big 1 :D Quote Link to comment
Jayden71 Posted May 20, 2011 Report Share Posted May 20, 2011 Maybe you two shoulda taken some oics!! Or it didn't happen :fu: Quote Link to comment
chester Posted May 20, 2011 Author Report Share Posted May 20, 2011 i know i should have pics but i wanted to get it done before it rained and that didnt happen Quote Link to comment
Jayden71 Posted May 20, 2011 Report Share Posted May 20, 2011 You better post somethin pretty soon, like boobs, or no one is gonna halp you Quote Link to comment
Stoffregen Motorsports Posted May 20, 2011 Report Share Posted May 20, 2011 CWC is a cam casting brand. I5 is part of their name (I think). "A" is the stock number, as in U20 A. There were usually A, B, and C in stock form. The 685 doesn't ring any bells. You can send it out to a friend of mine, John Dougherty, and he'll tell you what it is. http://www.drcamshafts.com/ Quote Link to comment
chester Posted May 20, 2011 Author Report Share Posted May 20, 2011 hmmm ok, yeah wide14u was there and from looking at a stock u20 cam b and this cam being talked about you can visibly see that this cam is bigger I should mic it and go from there. and what do you mean by send it? you mean the cam if so that will be kind of hard since it is in the truck and my dd Quote Link to comment
banzai510(hainz) Posted May 20, 2011 Report Share Posted May 20, 2011 CWC I believe is a atermarket casting. MY Schneider has it and my 2 Webcamshfts has it. So I believe you have a after markets cam shaft and I dont know but you could look under Schneider and see maybe they have a profile number that will corelate. But I HOPE however put it in didnt just put a cam in there with stock retainer and stuff as that why it could be noisier. I notice if stock retainers are used and say a 160/170 size pad will fit in there as the book says but it coulld rock around as there is half the lash pad isnt secure in the cup(retainer). also hopefully wipe pattern is in the center also. Schneider lists .006 / .008 cold on valve lash Quote Link to comment
