adjusted valves and its noisier
I finally got around to adjusting my valves on my 71 521 l16 a87 head lazorite crate engine with original pollution control and now it's noisier. Way noisier. There was a tick I wanted to get rid of and check the specs. It does drive better now at lower speeds. Intakes 1 2 3 were touching. what gives?
1 2 3 4
intake .000 .000 .000 .0045 before adjusting
intake .008 .008 .008 .008 after adjusting
exhaust .013 .012 .013 .012 before adjusting
exhaust .010 .010 .010 .010 after adjusting
  • Replies 10
I did them cold. I have loads of room for adjustment so they can sink all they want for decades to come. I just dont see why the intakes need to be so tight to not tick. The engine was replaced in 1985 and I'm going to do some figures to see how many miles are on it. I dont think its that many. It doesn't even smoke on start up.
I have 2 sunk valves on my other 521 l6 w53 head with no room for adjustment left. way under specs touching on one. it doesnt tick at all. smokes on start up though.
1 2 3 4
intake .00 .00 .00 .045 before adjusting
intake .08 .08 .08 .08 after adjusting
exhaust .13 .12 .13 .12 before adjusting
exhaust .10 .10 .10 .10 after adjusting
You might start with the correct specs, unless you just typed it wrong. There is a huge difference between the numbers you posted and the correct specs. Sounds like you have does Datsun valves before though, so i bet you typed it wrong.
Intake, Hot 0.010in. (0.25mm)
Exhaust, Hot 0.012in. (0.30mm)
Intake, Cold 0.008in. (0.20mm)
Exhaust, Cold 0.010in. (0.25mm)
They run tight because they dont expand with heat as much as exhaust valves do. Hence the bigger clearances for them. WHat 'feel' did you use for adjusting them? Did the gauge slide in and out with no friction? slight catch? have to force it in? LOL this souns awful, but i cant think of a better way to describe it.
You do know that if you drive the truck with your foot into the pedal a lot, the valves are going to sink right into the head fairly quickly, unless you have put hardened seats in the head, the brass seats(original) just don't work with unleaded gas, I drove to florida from washington and back on a fresh head, by the time I got back(about 8000 mi.), I was out of adjustment on some of the valves, that head was a W53, with big valves and it was ported to match the SU intake.
68datsun 510, My L20B was junked ??? the whole motor????????just have head redone.
I set my valve lash to .006 .008 cold.
Maybe try 40wt from the Korean store down the street from you?
earlier head the seats might sink sooner cause they are a different material . then when unleaded cam the newer heads have better seats.
I just dont like swapping out valve seats unless I kow the machinist is good. YOu could pay alot of money then wham a seat seapareates cause the guys didnt dod it right. One reason I dont do 44mm intakes valves. I just dont want to risk it for a 14% bigger valve.
  • 3 weeks later...
ok I re-adjusted the valves to .006 intake and .008 exhaust and when I got to the last valve which was #3 exhaust it was loosened all the way somehow. maybe I didnt tighten it last time but the the ball stud had turned several rotations all the way down giving me something like .045 clearence on the lash. :blink:
no more ticking :D
