domn8tr Posted April 29, 2011 Report Share Posted April 29, 2011 I found a Crane cam in my spares. Specs are 7,41 lift and timing is Intake;11btdc to 41abdc for 232 deg and exhaust 56bbdc to 6atdc for 242 duration. Is this too wild for street use? Quote Link to comment
wayno Posted April 29, 2011 Report Share Posted April 29, 2011 To me, 741 lift sounds wild for strip use, I bet the valve springs would look industrial strength, you know, you set one on the kitchen table and look at it, and come to the conclusion that it might break the valve closing it. Quote Link to comment
banzai510(hainz) Posted April 29, 2011 Report Share Posted April 29, 2011 If I remember correctly the lift on the crane cams was .450 The duration is a little on the longer side.if esp at @.050 lift. best is higher lift and little bit longer duration for a street but, If you think its a Jackpot and got to use it ,Run it. Quote Link to comment
ggzilla Posted April 29, 2011 Report Share Posted April 29, 2011 Lift is not "wild" per se but certainly is very high. It does put a higher stress on the parts but won't affect the street vs strip usage like the duration will. More likely that valves will hit the piston tops. Plus that cam will require special valve spring that will not bind at such a high lift. Quote Link to comment
Dime Dave Posted April 29, 2011 Report Share Posted April 29, 2011 Nissan Comp L series valve springs coil stack at .700" lift which leads me to question that the lift is .741". I'm guessing "7,41 lift" might be at the cam in mm. 7.41mm = .292", with a 1.5 rocker ratio is .438" at the valve, which seems to make more sense. Another point of consideration is lobe center angle. Street cams like wider lobe centers than race cams. Typically 108-112 lobe centers are used on street cams. Based on the timing specs you list, the cam has 110 lobe centers and is installed with 5 degrees of advance. Advanced cam timing will shift the power band to a lower RPM range. If the lift is assumed correctly, this would be a mild street cam with good low to mid-range power, IMO. Quote Link to comment
domn8tr Posted April 29, 2011 Author Report Share Posted April 29, 2011 It's Crane part# 162-0012 grind # DA-272-2-10 4.71 lift. Cam Card says It requires springs # 99884 and Retainer # 903-0102 PART NUMBER: 162-0012 ENGINE TYPE: MECHANICAL SPECIAL GRINDNO: DA-272-2-10 ENGINE IDENT: 1968-1980 DATSUN-NISSAN "L" 4 CYLINDER 1595-1952 CC SOHC VALVE SETTING: INTAKE 0.15 MM EXHAUST @ VALVE 0.20 MM HOT INTAKE @ CAM LIFT: EXHAUST @ CAM CAM TIMING .254MM @ VALVE LIFT PART NUMBER 7.41 MM 7.41 MM INTAKE EXHAUST 11.43MM 11.43MM ROCKER ARM RATIO 1.541 @ VALVE ALL LIFTS ARE BASED ON ZERO LASH AND THEORETICAL ROCKER RATIOS OPENS CLOSES ADVERTISED DURATION 27 BTDC 65 ABDC 272 ° 72 BBDC 30 ATDC 282 ° SPRING REQUIREMENTS DUAL OUTER RECOMMENDED RPM RANGE WITH MATCHING INNER COMPONENTS CLOSED: OPEN: TRIPLE 99884 90 LBS 180 LBS INTAKE EXHAUST 42.1MM @ 31.4MM OPENS 11 BTDC 56 BBDC OR 1 21/32 MINIMUM RPM MAXIMUM RPM VALVE FLOAT 2200 5600 -- LOADS: @ CAM TIMING @1.0 MM VALVE LIFT CLOSES 41 ABDC 6 ATDC MAX LIFT 105°ATDC 115°BTDC DURATION 232 ° 242 ° TIMING FIGURES MEASURED AT VALVE USING ZERO LASH. RETAINER PART #903-0102 MUST BE USED WITH THE SPRINGS LISTED ABOVE. VALVE LASH CHECKED BETWEEN CAMSHAFT AND FOLLOWER. INSTALL SUPPLIED OIL PLUG. Quote Link to comment
domn8tr Posted April 29, 2011 Author Report Share Posted April 29, 2011 Sorry cut and paste changed format of card Quote Link to comment
Dime Dave Posted May 2, 2011 Report Share Posted May 2, 2011 Domn8tr, When I said yes it should be streetable I was thinking along the lines of today's trend of hybrid LZ engines, not the older L16 & L18 engines. Without particular engine details an answer is based on many assumptions. My "yes" was based on an LZ hybrid engine that is "undersquare" (longer stroke than bore) this helps make better bottom end power. The L16 & L18 engines are "oversquare" (bigger bore than stroke) which helps make better top end power at the sacrifice of low end torque. Undersquare engines can use a longer duration cam than oversquare engines on the street because the longer stroke is making low end power when the longer cam duration is shifting power toward the top end. So without a complete engine description it is very hard to say if your cam grind will work for you or not. Here is some input from others regarding the 162-0012 Crane cam. Note that all 6 cylinder L series engines are oversquare. This was posted to the Bluebird List back in January 2000 regarding this cam. The engine was a Z22 block bored .080" with Z24 pistons, L series head and dual 44mm SU's from a Z car. I selected a somewhat mild cam, Crane #162-0012 .450 lift 292 dur both int. and exh. to best utilize the long stroke of the Z22 crank, it is very torquey in the 2000-5000 rpm range, with the SU's it now pulls all the way to 6500 rpm. While the P/N is the same, the duration is longer than that shown on the timing card you have. In either case the cam (even a cam at the specs given in the post) is working for this individual on the street. Here is a link to the whole post: "LZ22" posted to the BB List 1/25/00 Another online article giving advice on Z car L series engines details a user's experience with the same Crane Cam grind as you have but in a Z car 6 cylinder. Datsun Z Garage - Performance Mods In that article they offer the following advice on cam selection. COMMENT: My feeling is that about 270 advertised degrees (230@.050") of duration is right for street/autocross situations. Datsun race cams from the 1970's would run durations over 300° but those are intended for constant high rpm driving in race prepared motors, not normal street driving. Many Datsun 510 owners have used a camshaft from Kelvin Dietz called the DAMB Cam. It has a 290 design duration with .540" lift. This cam is very streetable. But most of these were installed in hybrid LZ (undersquare) engines. Quote Link to comment
domn8tr Posted May 2, 2011 Author Report Share Posted May 2, 2011 Thanks Dave The motor is an L20b which according to SDSurf ( who I bought the 521 from) already had a "B' cam. I've since installed a Peanut head and weber 32/36 and I'm in the process of putting in a dogleg 5 speed and gonna hit Ecology pic a part in search of a 4:11 LSD and some Pathfinder wheels so I can do the disc brake conversion. I'm looking for decent mileage and enough power to haul my vintage two stroke streetbikes around.The cam came in the boxes and boxes of spares that came with my sons recent purchase of an autocross 510 2 door. He's dropping in an SR20DET so I get spares! Quote Link to comment
banzai510(hainz) Posted May 2, 2011 Report Share Posted May 2, 2011 power to haul my vintage two stroke streetbikes around thread Hi jack!!!!!!! I just sold my 2 strokes Yamahas RZ350 kenny Roberts 79 Daytona Special 75 Rd350 All L20s have B cams its stock. olddatsuns.com has my vid on how to ck the cam timming on the first part. Its EZ to see if a tooth off,dial crank to Zero and then ck the cam timming marks. But I have a feeling you know this already since you swap the head and how to line this up. Quote Link to comment
domn8tr Posted May 2, 2011 Author Report Share Posted May 2, 2011 FOOLDOG! no sell! no sell!!!! (2 Daytonas 1RZ350 1CS-5 1Suzi T-500) Quote Link to comment
