dennis Posted April 29, 2011 Report Share Posted April 29, 2011 Since I have my engine and tranny separated I figured I would change out the clutch and flywheel. I was wondering if I would have any issues if I were to run a Stage 3 clutch on a stock SR20DET. My plans are to upgrade to a disco potato and 555cc injectors once I get the stock engine running. I figure I knock it out since I am already in there. Quote Link to comment
banzai510(hainz) Posted April 29, 2011 Report Share Posted April 29, 2011 stage 3. How makes the clutch.? I know SPEC brands makes various stages of Clutches but most likely its the same pressure plate just different disc. Unless you have the specs on this or link us to a manfacture. I know when I sat in Jeff Hinos(Icehouse) Old beater510 with SR20DET. it had a stock clutch and its pretty dam stout as it is. If a girl has to drive it or is a daily driver one will not want to drive this thing everyday just for work. Quote Link to comment
Hoosier77 Posted April 29, 2011 Report Share Posted April 29, 2011 i would go with a stage 3 unless you are drag racing, drifting, or have a leg the size of hercules!!!!!!!!! I just bought the exedy stage 1, it is still a one peice friction disc with a slight upgrade in materials and just a little bit stiffer springs over stock, perfect for a little street abuse, just under 300$ it was in my price range, I would go spending 500-1000$ just on a clutch, go with the exedy stage one and you will be glad you did. Quote Link to comment
DISLEXICDIME Posted April 29, 2011 Report Share Posted April 29, 2011 I have a act. Clutch on mine and it is verry stiff but I like it like that Quote Link to comment
Sealik Posted April 29, 2011 Report Share Posted April 29, 2011 i would go with a stage 3 unless you are drag racing, drifting, or have a leg the size of hercules!!!!!!!!! I just bought the exedy stage 1, it is still a one peice friction disc with a slight upgrade in materials and just a little bit stiffer springs over stock, perfect for a little street abuse, just under 300$ it was in my price range, I would go spending 500-1000$ just on a clutch, go with the exedy stage one and you will be glad you did. Ya...I recently bought the same 1. This 240mm application is rated for 312 ft/lbs or torque I believe. Quote Link to comment
dennis Posted April 29, 2011 Author Report Share Posted April 29, 2011 stage 3. How makes the clutch.? I know SPEC brands makes various stages of Clutches but most likely its the same pressure plate just different disc. Unless you have the specs on this or link us to a manfacture. I know when I sat in Jeff Hinos(Icehouse) Old beater510 with SR20DET. it had a stock clutch and its pretty dam stout as it is. If a girl has to drive it or is a daily driver one will not want to drive this thing everyday just for work. I will be probably running the Exedy Stage 1. with either a Fidanza or Exedy flywheel. Any of you guys have lightened flywheels? it wont be a daily, more like a every other weekend driver or just whenever I want. My stock clutch has plenty of miles left on it but I like a tighter clutch plus I am looking for around 300whp Quote Link to comment
banzai510(hainz) Posted April 29, 2011 Report Share Posted April 29, 2011 I have a tilton 10pounder with my roadster clutch L16 and its fine. I lug it around all the time. Quote Link to comment
Icehouse Posted April 29, 2011 Report Share Posted April 29, 2011 Hainz my beater with the SR had a 3 puck stage 2 Exedy. That was an expensive clutch 400 I think. It grabbed hard though! Dillon has the same on in his green car, Frank has an 3 puck ACT stage 2 clutch in his turbo KA car, seems to feel the same as the Exedy. Quote Link to comment
dennis Posted April 29, 2011 Author Report Share Posted April 29, 2011 Hainz my beater with the SR had a 3 puck stage 2 Exedy. That was an expensive clutch 400 I think. It grabbed hard though! Dillon has the same on in his green car, Frank has an 3 puck ACT stage 2 clutch in his turbo KA car, seems to feel the same as the Exedy. Jeff, how much HP and TQ did the beater have? What mods were done? Quote Link to comment
banzai510(hainz) Posted April 29, 2011 Report Share Posted April 29, 2011 Dennis Jeff I believe was pulling 185 to 200 to the ground. when he was on Dyno.That clutch made my Roadster clutch fell like a Pussy maybe a stock type disc is better for daily driver than the ON/OFF feel of a Puck clutch http://www.importrp.com/ They do have the Daikin/Exedy clutches as Hoosier and Sealick have. Thats good as maybe its a beeter option for the L motor truck guys than finding a 200mm flywheel for the L20/22/24 and use the stage 1 or 2 in 225mm flywheels Quote Link to comment
dennis Posted April 29, 2011 Author Report Share Posted April 29, 2011 Dennis Jeff I believe was pulling 185 to 200 to the ground. when he was on Dyno.That clutch made my Roadster clutch fell like a Pussy maybe a stock type disc is better for daily driver than the ON/OFF feel of a Puck clutch http://www.importrp.com/ They do have the Daikin/Exedy clutches as Hoosier and Sealick have. Thats good as maybe its a beeter option for the L motor truck guys than finding a 200mm flywheel for the L20/22/24 and use the stage 1 or 2 in 225mm flywheels Im thinking the same thing, worst case scenario is I have to replace the clutch. I will probably just throw this badboy on along with a lightened flywheel http://www.frsport.com/Exedy-06803B-High-Performance-Stage-1-Clutch-Kit-S13-S14-SR20DET_p_1193.html Quote Link to comment
