Oil spooging L20B
Shouldn't be ring blow by, the motor has less than 10,000 miles on it. I think the reversal of the pcv breather is one of the culprits. The reason for the filter on the end is just in case it manages to reverse flow when the engine stops, or during decel, you don't suck dirty air into the crankcase.
Matt the stock set up runs a hose into the air filter housing between the carb and the filter element. It gets filtered air when the pcv is drawing air in and if too much blow by, it gets sucked into the carb so the filter stays clean.
  • Replies 28
I think that's what I was trying to say, but anyway, I have heater core issues on my mind now, Mike. I've replaced heater cores before, why does the D21 have to be such a pain in the ass?!
