L20 Block breather tube question
H20doctor
My engine is all together and bolted in.. I am running a webber 32/36 on a L20 intake.. No Pvc valve and side intake stuff thats normal on these engines with a Hitachi...
Where do i run the engine breather crank tube. ?
And How do i run a PVC valve on it ?
and what should it look Like when done .. Pics Please ...
my engine has a shorty exhaust header on it from Top end performance... http://www.racetep.com/nissan.html
  • Replies 9
L16s usually have a hole and tube that exits straight out the side of the plock, L20Bs exit upward. But in all cases the pipe directs crankcase vapors into the rubber tube that connects to a PCV valve mounted on the intske.
L16...
L20B...
It should connect to the black fitting under the base of the carb.
well as you can see my intake manifold had been welded up.. and all the egr stuff removed
this tube here connects to my Break Booster ....
and here is the line from my break booster, on my finger ...
And here is my Breather tube ..
So i ran my first engine with nothing on the crank tube for 40,000 Miles... it just vented downward on the exhaust maniold..
What should I put on the breather tube ? and what set up will work ..because i dont want it just venting like it was
I dont want to run it into my intake ,as I would guess that would suck oil into my valves and the tops of my pistons
This is how the factory designed it. There are baffles in the block vent to remove oil spray droplets and only vapors from combustion and moisture are sucked in.
Just saw this... Its from a '75-'77 L20B with the manifolds bolted together. The area with the heat riser valve has to be plugged like this if running a header. Nice.
