boxboy Posted March 19, 2011 Report Share Posted March 19, 2011 I need a new fuel pump spacer and gaskets for my J13 engine. Rock Auto says they are the same for pretty much any Datsun up to the early 80's. Can anyone confirm that? Quote Link to comment
boxboy Posted March 20, 2011 Author Report Share Posted March 20, 2011 After tracking down a new spacer and gaskets I have determined that the reason I am having such trouble getting this to seal is that the castings on the pump itself are dog eared in. So it is tight against the block where the bolts are, but not touching in the middle. So I have begun to file. I don't want to try to reverse bend them and risk breaking them off all together. So I have started removing material from the "ears" and trying to flatten out the piece that way. I hope it works. If not, I will be looking into an electric pump, or a new mechanical won if I can find it. More$$. Just what I need. :( Quote Link to comment
420n620 Posted March 20, 2011 Report Share Posted March 20, 2011 if you need one, just say the word, FREE . Quote Link to comment
datzenmike Posted March 20, 2011 Report Share Posted March 20, 2011 I found two part numbers for the J13.... the last one is identical to the L series. I say the same. Quote Link to comment
ggzilla Posted March 20, 2011 Report Share Posted March 20, 2011 If the casting is not flat, you can use silicone sealer. Put a 1/8" bead down and let it get tacky before putting the spacer and fuel pump on. Quote Link to comment
datzenmike Posted March 20, 2011 Report Share Posted March 20, 2011 I think the spacer is phenolic plastic and will crack if over tightened. About 10 ft lbs on the L20B. Quote Link to comment
boxboy Posted March 20, 2011 Author Report Share Posted March 20, 2011 10 ft. lbs is good to know. But with my engine in I can't get a torque wrench in there. I am using and end wrench. I am guessing just snug without cranking it down any will be sufficient. Just for reference if anyone else is looking and wondering, the L16 spacer works. It isn't an exact original fit, but it should do the trick. I got it from NAPA and it is Felco. $5 with the gaskets included. Quote Link to comment
zed1 Posted March 20, 2011 Report Share Posted March 20, 2011 Beck Arnely (J series) 039-2002 Fuel Pump Spacer 1 needed (two hole) 039-2008 Fuel Pump Gasket 2 needed (two hole) Beck Arnely (L series) 039-2001 Fuel Pump Spacer 1 needed (three hole) Definitely not interchangeable. Quote Link to comment
boxboy Posted March 21, 2011 Author Report Share Posted March 21, 2011 Woops. You are right Keith. The one I have is from an a series I believe. Napa said the Felpro part was good up to 91 in some vehicles, although I have no idea what would have used a mechanical pump that late. Anyway, I believe mine fit the B210 and several other applications as well as the 720 pickup to 1983 or so. Sorry for the confusion. Quote Link to comment
