SHADY280 Posted February 12, 2008 Report Share Posted February 12, 2008 so i got an 82 z 5 speed laying around, my truck has been nagging me to put it in. ive read it fits, but, what do i do as far as the clutch actuating cylinder goes and throw out bearing? use the one from the 4 speed, or use the stuff from the 5 speed, or a combo there of? i couldnt find it easy so i ask, i know that could be seen as lazy, but you guys are just too smart to pass up the chance to quiz you! Quote Link to comment
Pacific coast Datsun Posted February 12, 2008 Report Share Posted February 12, 2008 521 or 620? If for a 521 read this thread..i did the swap already... http://forum.ratsun.net/showthread.php?t=523 If for a 620 the mods needed should be close. Youll want to use the TRUCK clutch slave........ Youll want to use the TRUCK throw out bearing...... Youll also need a longer speedo cable...the 4 speed one will work but needs to be re-routed. Quote Link to comment
Bleach Posted February 12, 2008 Report Share Posted February 12, 2008 they really should be the same. a non-turbo Z uses a 225mm clutch kit just like an L20b in a truck. Just get a new kit for the truck and install it. Quote Link to comment
fiveNdime Posted February 13, 2008 Report Share Posted February 13, 2008 I did a 5spd. swap into my 521 as well. I can help with questions, but what is it going in? Just make sure the slave cylinder clears the tortion bar! Quote Link to comment
SHADY280 Posted February 14, 2008 Author Report Share Posted February 14, 2008 its going into a 75 620 reg. cab short box. the tranny is late model 280zx, 82 type. i got z speedo cable if required, but if all i got to do is re-route, and swap the gear, then thats o.k. i dont know how good the clutch is, it feels o.k. so im gonna chance that one, but am going to get the flywheel lightened a bit just help the rpms, screw drivability. Quote Link to comment
Pacific coast Datsun Posted February 14, 2008 Report Share Posted February 14, 2008 Ok then if the stock trans. is a long tail it'll be an easy swap w/ no driveshaft shortening needed. Id install a new clutch disc while it's apart..it's a cheap part. Quote Link to comment
SHADY280 Posted February 14, 2008 Author Report Share Posted February 14, 2008 o.k then, so just swap the slave, throwout (gonna get new) and im good, does the throwout include swaping the arm and the thing it sits on? (cant remember name) i was thinking of getting a 1 piece shaft made one day, just to eliminate the carrier. its not like its a long truck or anything. any disadvantages to that? oh one more, how bout the shifter location and how it fits/ length in cab? sorry last coupla questions b4 im ready! Quote Link to comment
Pacific coast Datsun Posted February 14, 2008 Report Share Posted February 14, 2008 In order of asked.... yes use the TRUCK slave not the Z one, if you hold them side by side youll see. The hose on the Z unit WILL rub the torsion bar/not work. Good idea on buying a new T/O bearing, take the old one in to make sure they sell you the right part.... The "clutch fork" wont need to be replaced but inspect it good for cracks & or wear on the "ears" [2 parts that push the T/O bearing]. Mine broke last Dec. & had to trailer it home... Id stay w/ a 2 piece shaft...if you lower it more that 4 inches the 1 piece shaft more than likely rub against the bottom of the cab.... The shifter will sit back a few inches & youll need to cut the cover plate a little. Easy & can be done w/ snips... factory tunnel opening w/ Z 5 speed installed....i believe the shifter sits back 2 or 3 inches..... Quote Link to comment
datzenmike Posted February 14, 2008 Report Share Posted February 14, 2008 The one piece will probably go through the X frame that holds the sarrier bearing. Quote Link to comment
yello620 Posted February 15, 2008 Report Share Posted February 15, 2008 In order of asked....yes use the TRUCK slave not the Z one, if you hold them side by side youll see. The hose on the Z unit WILL rub the torsion bar/not work. Good idea on buying a new T/O bearing, take the old one in to make sure they sell you the right part.... The "clutch fork" wont need to be replaced but inspect it good for cracks & or wear on the "ears" [2 parts that push the T/O bearing]. Mine broke last Dec. & had to trailer it home... Id stay w/ a 2 piece shaft...if you lower it more that 4 inches the 1 piece shaft more than likely rub against the bottom of the cab.... The shifter will sit back a few inches & youll need to cut the cover plate a little. Easy & can be done w/ snips... factory tunnel opening w/ Z 5 speed installed....i believe the shifter sits back 2 or 3 inches..... If i remember correctly the shifter position will stay the same as long as you are removing a long tail 4 speed and installing a long 5 spd. If you remove a short tail 4spd and install a long tail 5 spd the shifter will move a few inches. Quote Link to comment
SHADY280 Posted February 16, 2008 Author Report Share Posted February 16, 2008 wow, thanks for the pix and help guys, now i got to swap it. its gonna be a coupla months, the poor truck went to my house now, cause i got a customers 65 falcon to restore. money outweighs projects again!! Quote Link to comment
