BEEBANI Posted March 28, 2007 Report Share Posted March 28, 2007 I've seen either on here or NWDE lately someone talking about 620's with the electronic dist. needing a ground directly to the dist. My '76 has currently developed a timing issue and I'm wondering if not having a good ground to the dist. could be a problem? Quote Link to comment
]2eDeYe Posted March 28, 2007 Report Share Posted March 28, 2007 Do you run a ground from the dist. body to the motor? I would think bolting it to the motor would take care of grounding it. Interesting.... Quote Link to comment
Charboucher Posted March 28, 2007 Report Share Posted March 28, 2007 i'll take a look at mine today but I have a matchbox eltric dizzy, so i'll let you know whats hooked up on mine as soon as I can. migt be later tonight though, wife and kid are sick :( Quote Link to comment
BEEBANI Posted March 28, 2007 Author Report Share Posted March 28, 2007 I don't know, I caught someone saying something about it in a thread. It started running like shit when Jeff was down and I haven't been able to figure it out. The only thing that has changed in the last six months is the new coil I put on. I noticed yesterday that there were extra wires coming off of the resistor. I looked at the wiring diagram and found that there was supposed to be an external condensor (which has been removed) and the wires were taped up. If I could get a picture of the resistor and how the wires are attached, the wiring diagram only gives you wire colors up to the resistor but not the ones that actually go to the coil. Quote Link to comment
hang_510 Posted March 28, 2007 Report Share Posted March 28, 2007 your new coil could have an internal resistor ??? the matchbox dizzy does not require any additonal resistance. HTH Quote Link to comment
BEEBANI Posted March 28, 2007 Author Report Share Posted March 28, 2007 Nope, it says right on it external resistor required. Quote Link to comment
datsunaholic Posted March 28, 2007 Report Share Posted March 28, 2007 That's because the Cali '76 EI system used the points-type coil, so when you buy one in the store they sell you the external-ballast required type. The problem is, the '76 Cali system is completely different than anything else. The EI box uses the ballast resistor (the '76 Cali system has a 4-terminal, twin resistor setup) to ballast out both the coil and the EI module. So to get a "Picture" you'd have to find someone with a '76 Cali truck that hasn't been modified. Not a simple thing, since '76 trucks are mostly just parts sources (especially in Cali). Quote Link to comment
BEEBANI Posted March 28, 2007 Author Report Share Posted March 28, 2007 So how would I hook up a 78-80 coil to this system and get rid of that resistor? Quote Link to comment
datsunaholic Posted March 28, 2007 Report Share Posted March 28, 2007 OK, I misspoke- don't need the resistor for the Ign Module. That 4-terminal resistor had me a bit confused because my astigmatism makes following the little lines a pain. OK, here's how it's wired: The 5 terminals on the Ign Module are (from Black wire) - Ground (Black) - 12V Ign (Black/white stripe I think) - Coil Trigger (Blue). This feeds BOTH the Coil (-) and the Tach Signal. - Dist Pickup Feed (Red) - Dist Pickup Return (Green) The bottom 2 (Red and Green) go straight to the distributor, do not pass go, nor do anything with the coil. They do have a terminal block inline (usually attached to the radiator) but it's just a connecton box. The Resistor Pack has 4 connectors: Top ring lug: Terminal for Coil Fire (it just provides a lug, it's not connected at all to the resistors). Has 2 wires, one goes to the center connector on the EI module, the other to Coil Neg. Top spade connection: Resistor Output. Has 2 wires: one goes to Coil (+) and the other to the Condenser. The other end of the Condenser is Ground. Bottom Spade connection: one wire, 12V "Start" connection (goes to key switch, only live on Start). Bottom ring lug: Ignition feed. Comes from fuse box (switched 12V)- on with Ignition. The problem is the diagram says the 2 spade connectors- one to Condenser, the other to START both show as the same color wires. Dumb, but only the Cali version used that funky resistor. It never sends 12V to the coil, the START just has less resistance. So, to clean it up to use a EI (unballasted) coil, you hook the 12V IGN feed (Black white stripe) to coil Positive, leave the START wire off, and hook the coil trigger wire to the Coil (-) terminal (blue wire). If you really want the condenser, hook it to coil (+) and ground the other side to the fenderwell. This would retain the original 5-wire remote box. Quote Link to comment
Pacific coast Datsun Posted March 29, 2007 Report Share Posted March 29, 2007 Jason you may be looking for the thread i started regarding the EI swap using the GM HEI module. Heres the link...btw over @nwde I responded too..:cool: http://forum.ratsun.net/showthread.php?t=203 Id go this route & eliminate all the "tweeker" wiring issues. Quote Link to comment
