datzenmike Posted June 26, 2012 Report Share Posted June 26, 2012 They will all bolt on to each other but... '78-'80 exhaust ports are round... all other years are square. A square manifold will work on a round port head (barely) better than the other way around. All L20B manifolde are 4 into 1 with a single large round connection to the down pipe. All earlier ones are 4 into 2, with 2 smaller outlets into a two pipe down pipe. All '75-'77 L20B exhaust manifolds are also bolted together with the intake manifold. Does that help? Quote Link to comment
Dawa Posted July 17, 2012 Report Share Posted July 17, 2012 ^ just now saw this. it definitely helped ME. thanks for the info Mike. the reason i was asking is if i buy a bare l20 block im wondering if i can use the intake/exhaust manifolds from my l16. Quote Link to comment
banzai510(hainz) Posted July 17, 2012 Report Share Posted July 17, 2012 Early L20 had square exhause port heads(U67) Later had round port heads but if you use your squreport head yes the L16 stuff is perfect however the L20 will raise the exhaust up about 3/5 inc so calculated on that if hitting the floor of the truck or exhaust hitting trans x memeber Quote Link to comment
Dawa Posted July 17, 2012 Report Share Posted July 17, 2012 ^ ah damn. well thanks for that bit of info :) Quote Link to comment
Dawa Posted July 23, 2012 Report Share Posted July 23, 2012 Hainz, the l20 im buying has the square ports and im not going to swap the heads. will the l16 exhaust manifold on the l20 (installed in a 620) have the clearance issue? i apologize, i get confused very easily... Quote Link to comment
banzai510(hainz) Posted July 23, 2012 Report Share Posted July 23, 2012 The exhaust manifold is not really the proplem. Its the Y pipe that fits it. As you have a truck youll nned the correct down pipe for that manifold tso it bends correctly and clears the bar. Thus when the motor is taller it will move up also about 3/4 inch. or get a new eaxhaust flange from Mklots and have a new Y pipe made. to clerwar this. Or maybe if you have the ealry 620 you can shorten or make your Y pipe work if still good. Trial and error fit best to ask a truck guy like Datfoug,Datsunaholic, Datzenmike ect..... Quote Link to comment
