RATDAT3 Posted April 19, 2011 Report Share Posted April 19, 2011 Looking good! Looks like they welded to the frame as well-----real tough! Quote Link to comment
RAlly_DatoB210 Posted April 21, 2011 Report Share Posted April 21, 2011 do you need a gas tank? i have one from a 78 510 hatch if you wanted to get some test fit sizing? Quote Link to comment
Morrisun Posted April 21, 2011 Author Report Share Posted April 21, 2011 Thank you for your offer and as time goes on that gas tank maybe a good option. I bought a pile of 1200 parts along with a very nice coupe body about a year ago and most of the parts were coupe specfic, and 4 very nice rust free gas tanks were in the pile. Coupe tanks are hard to find. If the tank you mentioned is out of the car, I would like a photo of to see where fittings and filler are located. Thanks again. Albino Smurf. Quote Link to comment
RATDAT3 Posted April 22, 2011 Report Share Posted April 22, 2011 You bringing it to Canby? Quote Link to comment
RAlly_DatoB210 Posted April 22, 2011 Report Share Posted April 22, 2011 i have it out but its under a pile of parts i believe that it might be too wide. filler is on the right side but is an absolute bitch at the pump. just casue the angle it wont let you pump for more than a few seconds at a time. bolt holes are all around the the outside metal flange but i would suspect you would need to drill new ones. no clue on the condition and i live a few hours away. Quote Link to comment
ggzilla Posted May 28, 2011 Report Share Posted May 28, 2011 hi doug, got some pics of Coupe fuel tank see Datsun1200.com Fuel Tank, USA section. Quote Link to comment
KELMO Posted May 28, 2011 Report Share Posted May 28, 2011 If you need more info on where the evapo hoses go, just let me know and I can take more detailed pics or give a good description. Quote Link to comment
Morrisun Posted May 28, 2011 Author Report Share Posted May 28, 2011 Spare tire/gas tank area The bracket laying in the trunk was spot welded under this area and allow the water that leaked into the spare tire well allowed water to sit on top of it and rust through. I will cut the bottom of the well and weld new sheet metal in minus the spare tire hold down- spare tire? I don't need no bloody spare! From bottom side...bracket mounted to bottom side of spare tire well holds gas tank up in place. Removed to repair spare tire well-Y'all won't happen to have one laying around looking for good home?? NOT likely this problem is common with coupe trunk areas. Gas tank just abit rusty and patched holes- I have another gas tank to put in. POR 15 on front floors. Needs seam sealer, warm days? Still need to remove steering column, grind firewall and treat with POR 15. POR 15 cowl on both sides-needs seam sealer replaced-waiting for another warm day. As far as Canby goes I don't think so. My papers are not in order and I have to replace the brake system and replace the clutch master and slave cylinder and reprimer the Jeep! Narrowed RX7 rear end with 10.25" dics brakes ready for paint then install into SMURF which would free-up a rebuilt rear brakes for Albino Smurf, just need to sort out my priorities! Quote Link to comment
MicroMachinery Posted May 28, 2011 Report Share Posted May 28, 2011 This thing's lookin' good man. Keep up the good work. Quote Link to comment
