TOKICO STRUTS Question
72nismo
  • Replies 24
What are the tokico struts you are using when running ZX Struts???
And I was told about using adjustable ones. What is the difference?
I know its adjustable but?
ZX strut tubes on 510? shortened? You mean tokico shocks?
I'm running shortened ZX struts/coilovers with tokico BZ3099's, they are the rear toyota MR-2 illumina's.
For stock ZX struts I would guess you just use 280zx stuff. Tokico illumina BZ3038 for stock 280zx struts I think.
Hope that helps.
Yes shocks for the front.
Dou happen to know how long the cylinder on that shock is?
Hope that helps.
Do u mine telling me how much u pay for the shocks??
$250 before tax off ajusa.com, for two BZ3099's. (those arrive tomorrow, I got a pair with the car but one of em is shot)
But I didn't know there was a tokico distributor on here, hmm.
This is maximum height on 14" wheels, FYI.
http://img443.images...10129131459.jpg
stupfast
keep that car orange.
when one measures struts they go from the weld to bottom of the out side tube.
280zx cartridges usually have a stopper on the bottom that could be cut off to make it even shorter. If too short add soem steel washersa as a spacer.
also be careful depending opn wheel the threaded collar or that adj spring perch the spring site on could hit a tire or rim if you have a more positive offset wheel. the more you go to zero offset on a 7in rim you mite need to roll the fenders. or find a 6in rim
Cool. Now I have to find the part number for the 5 way adjustable zx shocks..
Thanks for info
Well, with the current setup is it as low as you want it? If so, just go with stock ZX shocks. The only advantage I see for the shortened setup is for going very low.
  • 3 months later...
i read u can run e30 koni yellows on a 280zx strut with either some spacers or a shortened zx strut and in my opinion koni yellows are the best..what do u guys think... i hink thats gonna be my new set up
What is the part number for the Koni's?
