Pertronix Ignitors do fail
zed
the Ignitor module failed on my L18 yesterday. I installed it around 2008, maybe 70 000 miles back. Pity it gave no warning until the moment it died - leaving me stranded on a hot day with two dogs on the truck. Didn't take long to replace the old points and condensor though. I suppose I worked the Ignitor too hard - because I modified the ballast resistor by shortening the resistor wire until the current on the primary ignition circuit was just under 4 amps, including the coil resistance - which is the maximum current the Ignitor can take. I'm running a 40Kv Magfire coil, 1,1mm plug gaps. Anyway, the truck runs just as well with points
  • Replies 6
when else is it gonna fail?
in the early 90's i found points avail at a part store in mexico! :cool:
always smart to carry a spare _______ !
