benzo Posted January 26, 2011 Report Share Posted January 26, 2011 Hi anyone have a good source for new ones for a 510 or if they can be made? mine is not the prettiest and could use a new one as the factory wires are sketchy. Quote Link to comment
Pacific coast Datsun Posted January 26, 2011 Report Share Posted January 26, 2011 Mine blew on the wagon awhile back. I replaced it with a thicker gauge wire & new connectors. Been fine ever since thankfully. Quote Link to comment
Guest DatsuNoob Posted January 26, 2011 Report Share Posted January 26, 2011 What do they look like, if you have a pic, I think I may be able to hook you up Quote Link to comment
thisismatt Posted January 26, 2011 Report Share Posted January 26, 2011 http://www.madelectrical.com/catalog/fusible-link.shtml http://www.amazon.com/s?ie=UTF8&rh=n%3A15729691&page=1 Quote Link to comment
motavated Posted January 26, 2011 Report Share Posted January 26, 2011 I got like 3 feet of fusible link wire... I burned them when I am messing with alt... Quote Link to comment
ggzilla Posted January 26, 2011 Report Share Posted January 26, 2011 New from Nissan -- $4.50 Quote Link to comment
JohnnyD Posted January 26, 2011 Report Share Posted January 26, 2011 I went to Cost Moar, and bought blade fuses, some spade connectors, and 4 blade fuse holders. Total: 12$. Looks nicer and if the fuses ever blow, you get 4 for like 3 bucks. I kinda like it! Less OEM but also less fire & brimstone if they DO explode. That was kinda skurry the first time it happened... yesterday. lol Quote Link to comment
benzo Posted January 26, 2011 Author Report Share Posted January 26, 2011 not sure if I am calling it correctly but mine is a ring terminal on the starter that goes to a plug connnector. the wire broke off the ring connector so the car would not start but I fixed it for now and it starts but the wire is so old and frail that it may not last. I think someone local to me has one but have to look at what connector I have on the end. I will check the dealer also since ggzilla says it may be still available thanks for all the help Benzo Quote Link to comment
ggzilla Posted January 27, 2011 Report Share Posted January 27, 2011 Here's the stock Datsun type, goes on the battery cable for Datsuns I've worked on. Does the 510 use the green one? Quote Link to comment
Creepy Cruiser Posted January 27, 2011 Report Share Posted January 27, 2011 I just have a huge roll of 70A fusible link wire and make them myself. You can also grab them from any hardbody and pathfinders at the wrecking yard. Quote Link to comment
