Guest DatsuNoob Posted January 21, 2011 Report Share Posted January 21, 2011 Anyone here ever do this on a Nissan engine? I remember setting em up in auto shop class on a V8 back in the day. Was good for a few extra ponies. Where could I buy shims to do something like this on a KA? Quote Link to comment
bananahamuck Posted January 21, 2011 Report Share Posted January 21, 2011 Doesn`t the plug go straight into the top of chamber on a KA like yours?? If so moving plug in and out wont do anything ,plug indexing was used when plug went into chamber at an angle so spark would be completely exposed to piston.But honestly cutting the end off of the ground wire ( the bent part ) then gapping that against the electrode seemed to do just as much,,But now they make plugs that way from the factory. Quote Link to comment
Wide14u Posted January 21, 2011 Report Share Posted January 21, 2011 i haven't seen that done to a nissan motor Quote Link to comment
Guest DatsuNoob Posted January 21, 2011 Report Share Posted January 21, 2011 I was more or less curious if it would be beneficial on a KA to face all plugs towards the intake sides of the combustion chambers in the head. Quote Link to comment
Wide14u Posted January 21, 2011 Report Share Posted January 21, 2011 i think there is a plug that has a ring at the bottom instead of electrode at the bottom so there is no blocking Quote Link to comment
Guest DatsuNoob Posted January 21, 2011 Report Share Posted January 21, 2011 hmmm... I think I'll stick to factory recommended plugs since the fiasco of throwing a set of E3's into the Cooper. :rolleyes: My ECU was showing a Cyl#1 misfire code from running a set of "hot" plugs. Thanks for the reply though. Quote Link to comment
I'm BLUE Posted January 21, 2011 Report Share Posted January 21, 2011 i haven't seen that done to a nissan motor L-series ^^^ ,,, 1 ford and 1 chevy I have done this too ,,, all the little things one does are always beneficial as we all know ,,, I personally have no clue on a KA Quote Link to comment
]2eDeYe Posted January 21, 2011 Report Share Posted January 21, 2011 I've done it. No seat of the pants power increase that I could tell. Quote Link to comment
Guest DatsuNoob Posted January 22, 2011 Report Share Posted January 22, 2011 okay, thanks for the confirmation Redeye :) Quote Link to comment
