Llittle_Llama Posted March 16, 2008 Report Share Posted March 16, 2008 so all i have got do is make the hub a little smaller in diameter? and that can be done on a brake lathe for turning rotors? i have access to one reason i am asking. what did you "set" it on to turn them? Quote Link to comment
yello620 Posted March 16, 2008 Report Share Posted March 16, 2008 These hubs are a super soft metal, and turn super easy. Set the lathe on a slow/medium speed and go for it. Should be super easy. Best if you only machine it down to barely fit the hub bore of the titan. You then creat a hub centric wheel fit. Which means that they are perfectly centered and your tires will run "true" as possible down the road. Much better than relying on the lugnuts to center everything as good as possible. Aslo a better idea than running spacers. Jason Quote Link to comment
ariascarlos1990 Posted March 16, 2008 Report Share Posted March 16, 2008 how would i go about taking my front hubs off? do they just pull off? Quote Link to comment
fisch Posted March 17, 2008 Report Share Posted March 17, 2008 how would i go about taking my front hubs off? do they just pull off? Howdy! If you go to http://www.the620.com/ You can download the manual for your truck! Of find a chiltons or a haynes manual. Quote Link to comment
