novita1021 Posted January 13, 2008 Report Share Posted January 13, 2008 i hooked up a sterio on my 510 with two amps one for the sub and the other for my mids....wheni have low volume you can here a buzz or static...when i turn on the wipers or honk the horn or do anything that trigers a light there a little pop in the music thats playin...my dad says that it sound like that because of the distributer....but i dont know...what can i do to get rid of that little sound???:confused::confused::confused: any help will be great... Quote Link to comment
DISLEXICDIME Posted January 14, 2008 Report Share Posted January 14, 2008 are you running the rca's near any power wires? that will cause it to humm also make sure you have a good ground. Quote Link to comment
novita1021 Posted January 14, 2008 Author Report Share Posted January 14, 2008 no the wire that has power next to the RCAs is the remote for the amps.... Quote Link to comment
Fineline Posted January 14, 2008 Report Share Posted January 14, 2008 I was thinking ground as well. Its best to have them all grounded to the same place with a good size wire. Quote Link to comment
fiveNdime Posted January 15, 2008 Report Share Posted January 15, 2008 I know it sounds wierd but you can get interferance from the coil. I put a a condensor on my power side to lessen the noise. A good ground helps, and make sure all your other components have a good ground, like lights, switches, electric fuel pump?, Motor, etc. Pic of Resistor to positive side. Quote Link to comment
novita1021 Posted January 15, 2008 Author Report Share Posted January 15, 2008 thanks for the info im goin to try that when i have time...cuz i dont have time this week but yeah ill keep yall posted....:D:D:D Quote Link to comment
novita1021 Posted January 21, 2008 Author Report Share Posted January 21, 2008 hey i tired to do that but it was a lil confusing...cuz im realy not sure what wires go to what and all that in the pik it only shows one wire pluged to the lil white square i have two one on each side...so realy not sure what to do???:(:confused::(:confused: Quote Link to comment
pl521sss Posted January 22, 2008 Report Share Posted January 22, 2008 You can also get noise cause it's lousy brand of Stereo. My first 2 stereos were some generic names that had a whopping 1000W from the flea market. Lots of noise and made a loud click everytime it's shut off. Since then, been only getting quality stereo. Never had any issue since then. Like the saying goes, you get what you pay for. Grounding is likely the culprit. Just my 2 cents Quote Link to comment
Cruzn620 Posted January 22, 2008 Report Share Posted January 22, 2008 i run 4 gauge power and grounds on my system from the battery to the amp. off the battery have a 75 amp fuse about a foot from your battery, then run that into your cab, to your amp, then run a 4 gauge ground from your amp to a ground (i always ground to my seat mounts) i run my remote wire with my power wire down the drivers side of the vehicle, then my RCA's down the passenger side. let us know what else you find out with it! Quote Link to comment
datzenmike Posted January 22, 2008 Report Share Posted January 22, 2008 Good advice Tyler. Be sure that the ground from the body back to the neg terminal is also 4 ga.also. Many people over look the return, it has to carry the same current as any where else in the circuit. A digital multimeter will tell you if you are getting full voltage to your amp. At around 10 volts the transistors will pack it in. This will cause pops and groans when other accessories are turned on causing a low voltage (negative spikes) Clean all connections and contact surfaces. Mine had poor contact at the inline fuse holder that only a digital meter could show. Quote Link to comment
drastic520 Posted January 23, 2008 Report Share Posted January 23, 2008 Cruzn620 hit it right on the head.... Quote Link to comment
