jrock4224 Posted December 20, 2011 Report Share Posted December 20, 2011 ooo a magic carpet! What sort of MPGs do you get with one of those? i get about .7 light years per oscilation....its older so its not effeicent as the new duo processed oscilators...but the chicks really dig it... Quote Link to comment
DanielC Posted December 20, 2011 Report Share Posted December 20, 2011 This will give you a good idea where the shifter ends up in a 521 with a long 5 speed. The picture was taken with the transmission in 2nd gear. I took the original cover plate, cut the hole farther back, and used the metal from the new hole to plug the old hole, with two pieces of scrap the make up the shape difference in the old and new hole. Quote Link to comment
jrock4224 Posted December 20, 2011 Report Share Posted December 20, 2011 i guess thats not to bad i was thinking it would comeout of the seat .... i kinda had to come up withthe morph tranny as i dropped the 620 tranny and broke the tail shaft seal off it ....but thanks for the visual... Quote Link to comment
ggzilla Posted December 20, 2011 Report Share Posted December 20, 2011 Running an engine at it's torque peak RPM, is where it is most efficient. True. Ideally, this is the speed you like to cruise at. That would give you the best economy. Not true, unless the power needed to cruise coincides with the peak power of the engine at that RPM. But with L16 at the torque peak RPM, it makes far more HP than needed for crusing. Crusing at 2k will give you 50% more fuel economy than the peak torque RPM. This is because pumping friction triples with RPM increase, while power only doubles. This is why when a 5-speed is installed, the fuel economy goes up, even though the engine is running below the the torque peak RPM. The L16 can cruise at 2000 RPM, in fact they are safe for full-throttle starting at 2000 RPM. And part throttle from 800 rpm. The L16 is a very very good engine. So good that you can run it at 5000 RPM all day on the freeway with no problems. Or 2500 RPM which where I'd want it for flat freeway crusing with a 5-speed. If you need to accelerate there is always 4th gear. Quote Link to comment
KlassicMotion Posted March 10, 2012 Report Share Posted March 10, 2012 stock rear gear in most if not all 510s is 3.90s My Automatic 510 has a 3.70 rear gear Quote Link to comment
