electonic dizzy coversion kit
laniadude
  • Replies 8
Look almost like a Pertronix conversion. or a offshoot of the pertronix. Maybe soembody got mad and left the company.
if you have a bunch of single point dizzys l16 type then you can use these. l20s you need to machine the ring of the dizzy to make these work.
If made in japan or USA its good. if China dont buy it. but a matchbook is better.
but with this conversion use the stock coil and ballast. Believe me.!
How much more is a pertronix unit that does the same?
Also, be wary of the reman matchbox units. Someone, either here or on the realm opened one up and the electronics inside were very low quality. The unit physically weighed half of a Nissan unit.
about the same $$$
ive had 3 reman w/o any issues.
some do NOT come w/the black/matchbox, those are the ones to be wary of.
dont recall what 'electronics' were inspected... got a link to it???
How much more is a pertronix unit that does the same? Also, be wary of the reman matchbox units. Someone, either here or on the realm opened one up and the electronics inside were very low quality. The unit physically weighed half of a Nissan unit.
looked and weighed identical. actually a very quality part. i would reccomend one to anyone in portland/vancouver.
