pharouh Posted September 4, 2010 Report Share Posted September 4, 2010 Hi, I need the throttle cable bracket for an early 620 w/L16-stock carb. This is the cable I have. I may have the wrong intake-it's from a 510,and there's no mounts on the back of it. Thanks Link to comment
Z-train Posted September 4, 2010 Report Share Posted September 4, 2010 I have a LZ-23 with a Weber 7 a L-18 intake.I had to fab my own. Link to comment
pharouh Posted September 4, 2010 Author Report Share Posted September 4, 2010 I may have to do that too. Link to comment
Craig Posted September 4, 2010 Report Share Posted September 4, 2010 i still have my parts truck, it a 77 and has the l20b in it, let me know if it can work for you Link to comment
pharouh Posted September 5, 2010 Author Report Share Posted September 5, 2010 Thanks Craig. Do you have a pic? Thanks Link to comment
Craig Posted September 5, 2010 Report Share Posted September 5, 2010 hey i will have a pict for you on tuesday Link to comment
Charlie69 Posted September 12, 2010 Report Share Posted September 12, 2010 The stock bracket mounts on the 2 carb mounting studs closest to the master cylinder on top of the carb. Same nuts hold the bracket & carb. Let me know if you do not find one. I am cleaning the garage & might have 1 or 2. Link to comment
pharouh Posted September 12, 2010 Author Report Share Posted September 12, 2010 Thanks Charlie, Jefe had one. I should get it in a few days. Link to comment
Braden Posted September 12, 2010 Report Share Posted September 12, 2010 i have a custom made bracket you can have but you will have to show me the side of your manifold so i can see if it will work. mine bolts on the the side of this style manifold. i made it myself when i did my egr delete. yes i knwo the carb is on backwards Link to comment
Braden Posted September 12, 2010 Report Share Posted September 12, 2010 my bad i didnt relaize you had already found one Link to comment
