5dimer Posted September 2, 2010 Report Share Posted September 2, 2010 When Im going down the road it just wants to die and when I come to a stop it does die, it starts back up. So I dont know what to check first Quote Link to comment
jesusno2 Posted September 2, 2010 Report Share Posted September 2, 2010 check all the obvious stuff first fuel filter, fuel pressure, compression, ignition, then post back. I have a ka24e swapped and I have gone through every senerio diagnosing issues i had. Quote Link to comment
HRH Posted September 3, 2010 Report Share Posted September 3, 2010 Vacuum leak, check all around the rubber boots on the intake, etc. Quote Link to comment
INDY510 Posted September 3, 2010 Report Share Posted September 3, 2010 Is it a low RPM problem? Is the IACV tube hooked up right?.......... Did it work good before?......... I had a plug by the throttle body plugged in,, , but after un-wrapping the harness, it wasn't going anywhere... ... those aren't easy to find though The IACV is crucial for a good idle/cruising RPM..... Quote Link to comment
5dimer Posted September 3, 2010 Author Report Share Posted September 3, 2010 It was running fine and it just started to die when I come to stop. I'm not sure if it has to do with the starter I have a problem getting it to turn over but if I jump the starter it seems like the ignition turns on. Wtf!!!!!!!!! Quote Link to comment
datzenmike Posted September 3, 2010 Report Share Posted September 3, 2010 Clean and check battery cables, the ground on the block, add a good ground to the body, starter wiring and cables. Is battery being charged.... 14 volts when running? Quote Link to comment
5dimer Posted September 7, 2010 Author Report Share Posted September 7, 2010 I got it the connections on the starter where bad thanks everyone for your help!!!!!!! Quote Link to comment
