DanielC Posted January 2, 2008 Report Share Posted January 2, 2008 I glanced through the instructions that are for your wiring kit. I think they recommended drivers side mounting of the fuse box.. Do not mount the fuse box permanantly until you know all the wires will get to where you want them to go. The stock rear wiring harness has plugs that are down by the starter, I would consider leaving them, if they are in good shape. If your truck is like mine, the rear harness has a six pin connector plug, and a four pin connector plug. Only three of the four pins on that plug have connectors in them. The six pin plug is for the lights, and fuel guage sender. here is the color code on the harness I have. The harness is from a 1971 PL-521 394191 Yellow wire Fuel guage sender Red with Black wire Reverse light switch on transmission. Green with yellow Brake lights Red with blue wire Tail lights, Side marker lights, Licence plate light White with red wire Left turn signal White with Black Right turn signal The red with black wire stops at a connector by the reverse switch on the transmission. It then continues back, still red with black to the connector by the three pin taillight connector. The four pin connector is for the neutral, and third gear switch on the transmission. These switches are part of a pollution control system used on these trucks. 1/4 female spade connectors will plug into the six wires on the six pin plug. Quote Link to comment
BACARDI_DWB Posted January 2, 2008 Author Report Share Posted January 2, 2008 If i do mount it on the passenger side and its short i can always extend the wires. but i have installed this one before and they give you too much wire if anything. they made the kit so you can wire up a huge long vehicle. so the small 521 should not have a hard time reaching all the stuff i need to get to. don't get me wrong. i am going to keep as much of the good stuff that is hard to replace like connectors. I will splice whatever i need to. I have the wiring diagrams for it stored on my home computer. you don't need to name it all. but thanks anyways. Quote Link to comment
DanielC Posted January 2, 2008 Report Share Posted January 2, 2008 I am not assuming that you do not have all this information, but not everybody does have all the info. I like hearing info from another source, to confirm what I have is correct. I also hope somebody else will stumble across this, and other threads, and it will help them. Quote Link to comment
Pacific coast Datsun Posted January 3, 2008 Report Share Posted January 3, 2008 Clean 521..did you buy it from Marvin? I may have to re-wire my 620 so ill follow this build closely. Hit me up im in SD too...:cool: Quote Link to comment
BACARDI_DWB Posted January 3, 2008 Author Report Share Posted January 3, 2008 yes i bought it from marvin. he may end up picking up that truck from you. Quote Link to comment
sdsurf Posted January 4, 2008 Report Share Posted January 4, 2008 I test drove that truck and ended up buying another from the guy. Bacardi is right the brakes are a big IFFFF... Quote Link to comment
sdsurf Posted January 4, 2008 Report Share Posted January 4, 2008 I test drove that truck and ended up buying another from the guy. Bacardi is right the brakes are a big IFFFF... Yep Marvin is an interesting guy. Let me know on the Z22 build because I want to be in contact with him as well... Quote Link to comment
BACARDI_DWB Posted January 4, 2008 Author Report Share Posted January 4, 2008 I got my wiring today!!!!! I just did some research and i am not going to go with the Z22. i have a better idea of what i want to do. hehehehe. i am going to do some research thou and then post up my frankenstein. Quote Link to comment
sjeff64 Posted January 5, 2008 Report Share Posted January 5, 2008 does that seat(bench) hit the door panels? if not I would like to have the frame. I got an awsome late 70-early 80's N.O.S. bunch seat cover that is tuck and roll with the shifter relief.I cant find a seat to fit the 521 without cutting one down Quote Link to comment
