carl Posted August 21, 2010 Report Share Posted August 21, 2010 where is the voltage regulator located on a 79 620 with the camper Quote Link to comment
ggzilla Posted August 21, 2010 Report Share Posted August 21, 2010 It is built into the alternator (internally regulated). Quote Link to comment
carl Posted August 21, 2010 Author Report Share Posted August 21, 2010 It is built into the alternator (internally regulated). ok thanks.the problem that im having is the charge light is going on and off any ideas? Quote Link to comment
banzai510(hainz) Posted August 21, 2010 Report Share Posted August 21, 2010 change the alternator since the regualtor is in the alternator. get a volt meter and put across the battery and see what the output is and then turn on heater and see what the output is. If low its time to go. If regulateor is going ypu usually read a hight voltage and battery will slowly cook(oooz acid) Quote Link to comment
datzenmike Posted August 21, 2010 Report Share Posted August 21, 2010 ok thanks.the problem that im having is the charge light is going on and off any ideas? Check belt for tightness or wear and damage. Idle may be too low. Loose wire connection or loose plastic plug on the alt. Brushes may be worn or contaminated with oil. Quote Link to comment
carl Posted August 21, 2010 Author Report Share Posted August 21, 2010 the altenator is new was put in yesteday Quote Link to comment
carl Posted August 21, 2010 Author Report Share Posted August 21, 2010 I was driving the truck today and when the charge light came on I lost all the gauges what the hell is going on please help Quote Link to comment
ggzilla Posted August 21, 2010 Report Share Posted August 21, 2010 the altenator is new was put in yesteday New alternators are sometimes defective. Return it. If you had the same problems the day before yesterday, then the cause is not likely the alternator. You may have a loose wire somewhere. Quote Link to comment
banzai510(hainz) Posted August 21, 2010 Report Share Posted August 21, 2010 Battery cables? always get the molded end onesNot those pc together ones. they get corroded to fast Quote Link to comment
I'm BLUE Posted August 21, 2010 Report Share Posted August 21, 2010 alternators are sometimes defective. Return it. +1 ,,, ,,,, Re-Manufactured Alternators have a pretty high rate of failure that I have had experience with , return with receipt , grab another one , put it on , test again :D there are very few actual "new" alternators once one reads what qualify's as "New" ( it's pretty scary ! ) Did you tighten everything after installation ? :) Quote Link to comment
carl Posted August 21, 2010 Author Report Share Posted August 21, 2010 yea everything is tight Quote Link to comment
datzenmike Posted August 21, 2010 Report Share Posted August 21, 2010 Why was a new one put on in the first place? If it wasn't charging and you put a new one on and it doesn't either.... maybe it's not the alt. Quote Link to comment
