removing cylinder head from an L16 motor..
i tried finding a manual for my 71 but i think it is almost impossible to find it any car parts store
i havent tried online
so i got the intake system and the headers off by the way
now i just need to unbolt the head but i need to know the proper sequence on how to remove the bolts
does anyone have info on what thoes specs are.
do i have to remove alternator?
do i have to remove the waterpump?
anyparticular way i have to remove the camchaft cam gear timingbelt?
  • Replies 19
no bro, take off the valve cover and undo the 10mm allend head bolts, unbolt the cam sprocket, block timing chain with wood or tool and pull that sucker off!!! thats it!! well besides everything thats attached like the water housing (just uno the top hose) and all oft he other common sense stuff like plug wires
Manuals are all over eBay.
Head Bolt removal- start from the outside, work in a criss-cross pattern to the middle. Order isn't THAT important, the pattern is what you want. Install is from the middle-out. But don't forget the 2 small bolts holding the head to the timing cover- if there's grease you won't see them, and you can easily destroy the timing cover if you forget them.
Alternator: No.
Water pump: No. You don't have to remove anything not directly attached to the head.
There's no timing belt. It's a chain. And you MUST wedge the chain, or the chain will go slack, overextend the tensioner (which you cannot access from above) and fall off the lower sprocket. You MUST mark the timing chain and sprocket as to how it came off because it has to go back on exactly the same way.
If you don't wedge the chain, and the above happens, then yes you have to take off the alternator, water pump, crank pulley, oil pump, etc to take off the timing cover to reset the chain and tensioner.
Another thing.
What are the symtoms 1st. You see wter comming out from soemwhere?
Comming out of exhaust? remeber the l16 usues a water passage in the head from the intake so if loose intake to head and esp the lower intake exhaust bolt it coul suck water in to the intake making it look like a head gasket . Or you run it out of water that way till it over heats.
Tells us exactly whats going on MOFO
Another thing.
i still dont know what caused the headgasket to blow i doubt its failure of the cooling system im just thinking its the power of the motor and how it was driven
but yeah water mixed in with the oil i poped off the valve cocver and it looked like gravey hahah and some red watermarks
but after i replace the gasket i am going to check the water pump the thermostat and start running coolant instead of water =) and install a resivoir becuase it doesnt have one for the radiator
This is the L20B 0.040 over with flattops that turned out to be an L16. So did you buy it with a blown gasket or did you drive it for twenty minutes and it blew (which is the same thing) or did you drive it around for days and everything is fine and suddenly it blew???
Ok Now that helps. water in oil
Water in the oil could come from the water pump area.
Take the radiator out and take the water pump off. if it looks like a bunch of Termite holes then there is a high possiblity of a tiny hole in the front cover. If you can post a photo I can tell you if timming cover is suspect.Once the water pressureizes up the water goes behind the front cover right in to the oil pan
PS motor with aluminum housing need antifreeze mixture. It helpd prevent cavitation and bubles banging on the front cover. Mine went bad in 40k cause I kept running old anti freeze. it was green on the chimicals where wore out!!!!!!
So dont run only water
yeah its an L16 maybe bored to match l18 and i was told it has closed chamber head and flap tops,not shure still havent proven it my self i havent removed the head...
but when i purshased the car it had a new gasket then after driving it around for a wile is when the car started showing symptoms of a blown headgasket like white smoke over heating constantly checking water level...
maybe i was to rough =0 it was the longest ive driven my dream car
Only way you are too rough is if you let the water level go down. If the gasket was replaced then it blew before and the owner didn't check to see if the head is warped. I've done this, lasted a week or two and blew again.
When you bought it did you look at the oil on the dip stick? I'm hoping the oil wasn't contaminated from the previous blown gasket.
haha im starting to like ratsun haha thanks guys aprecciate the help
ps i love my datsun even thoe ive had the thing sitting around =0
you know what bro thanks for the help btw,,,
when i bought the car i took it to a shop so they could get it running for me and they did a tune up and changed the gaskets but now im really thinking that maybe since i fisrt started driving it for a wile i let the water level go down =( and maybe it over heated and thats what caused it to blow?? =/ maybe? but after it started to smoke i was constantly filling the radiator with water because i had to drive it home and it ran perfectly good strong actually.. so im really hoping there wasnt no serious damage i cant wait to get her up and running again!
and another thing even when they did an oil change when i would check the oil it looked a bit odd to me like it was contaminated almost as if it was watery like dark grey.. i did notice that when the car was running
if it helps i dont have stock carbs i have cu's
you know wat at first when u told me about the intake sytem possibly being loose.. that causes it to mix wit hthe oil?? im starting to take thatinto consideration because when the car was up and running the oil always looked a bit odd to me... i am running cu carbs from a 240z i beleive? i want webbers =)
If you want a physical copy, there are some on ebay for the haynes manuals.
http://cgi.ebay.com/...lsQ5fLiterature
thanks for the link bro
btw are thoes re finished original enkei datsun wheels? cuz they look like mines =) u seen my car ? wat u think? haha
NP.
They are Enkei stamped, so I assume they are original. The previous owner polished two of them, I'm going to do the others once I get the stuff for it.
.....Loose inttake will not cuase water in the oil
I've had at least three blown h/g, two were warped head. In all three, water in oil was not a problem, as there is no way for water to get into oil pan. If you drove it a long long time with a bad gasket water vapor can squease past rings and collect over time. But I think this is a bit of a stretch. There is an oil gallery between block and head but oil pressure would prevent water getting in only oil out. Never seen a gasket fail near the oil hole, nearly impossible.
