fivetenguy Posted July 23, 2010 Report Share Posted July 23, 2010 Guys, I am looking to replace all the bushings on my 620's suspension. I prefer Urethane bushings. I was told that Energy Suspension only goes back to '80. What are you guys using? I'm guessing you can use bushings off different years and makes? Quote Link to comment
zerow Posted July 23, 2010 Report Share Posted July 23, 2010 Try this guy. I picked up my suspension bushings from him for my 610. I know his listings on the website don't specifically call out 620s, but he is local to you: http://www.suspension.com/ Hope this helps! Quote Link to comment
fivetenguy Posted July 23, 2010 Author Report Share Posted July 23, 2010 Try this guy. I picked up my suspension bushings from him for my 610. I know his listings on the website don't specifically call out 620s, but he is local to you: http://www.suspension.com/ Thanks, Zerow! I actually tried him (Bruce) first. We always go to him to get our bushing for our Dimes. This is what he wrote me: Energy Suspension makes bushings for Nissan pick ups back to 1980. That is all. Bruce Quote Link to comment
Javin Posted July 23, 2010 Report Share Posted July 23, 2010 Try this guy. I picked up my suspension bushings from him for my 610. I know his listings on the website don't specifically call out 620s, but he is local to you: http://www.suspension.com/ Thanks, Zerow! I actually tried him (Bruce) first. We always go to him to get our bushing for our Dimes. This is what he wrote me: Energy Suspension makes bushings for Nissan pick ups back to 1980. That is all. Bruce I wonder if the 80s would work on my 78? Quote Link to comment
Gary Posted July 24, 2010 Report Share Posted July 24, 2010 pretty sure the book i got my rubber ones from said 520,620, and 720 were same for leaf bushes balljoint front end wise; the top control arm for the front suspension is near identical between 620 and 720, lower control arm looked very much the same too worth measuring and seeing if theyre the same before you buy/fit Quote Link to comment
yello620 Posted July 24, 2010 Report Share Posted July 24, 2010 I wonder if the 80s would work on my 78? Yes, they share the same part numbers in rubber replacements, so would assume that the urethane would work too. 78/79 only though. Quote Link to comment
dat620 Posted July 24, 2010 Report Share Posted July 24, 2010 the energy suspension bushings are correct for the 78/79 620 as the 80/81 720, i have them and have used them on my trucks, they just quit listing them 3 years ago, i get mine from a local vendor here in phx az. they are called performance suspension, ck em out at www.performancesuspesion.com Quote Link to comment
datzenmike Posted July 24, 2010 Report Share Posted July 24, 2010 the energy suspension bushings are correct for the 78/79 620 as the 80/81 720, i have them and have used them on my trucks, they just quit listing them 3 years ago, i get mine from a local vendor here in phx az. they are called performance suspension, ck em out at www.performancesuspesion.com Yes, the '78 and up disc brake 620 suspension parts are similar to the 720 through '82 I think. I wouldn't run Urethane, too stiff, transmitting too much road vibration and noise, they wear out faster because they chafe instead of flexing causing alignment problems and they squeak. Stock, when new, is more comfortable and will last the life of the truck. Be sure to tighten all suspension components with the truck on ground at ride height. Quote Link to comment
