What do ya do about 620 hanger bearing?????
  • Replies 7
Those bearing are trouble free. What goes bad is the rubber isolator. It splits and rots away allowing the drive shaft to flop around.
Redeye got my last one..... (but I got two '73 fender emblems for it.... sucker) Years ago I fixed this problem by cutting away the old rubber and metal ring and replace with a 2"? strip of 1/4" conveyor belt long enough to wrap around the outer bearing shell 5-6 times. I used stove pipe wire but a large gear clamp would be better. When wrapped the U shaped strap must clamp it down securely so cut only enough off to get it on tight. I only did this untill I could replace it ... but it worked so well I left it and it worked ace. The strange noise and thumping and shuddering was gone.
Thanks all. I call them hanger bearings cause that is what I had always heard them called on 2 ton trucks. I guess driveshaft support bearing would be more appropriate. Anyway would you have the part number,ghettobraden???
S'pose I can find them on line.
Thanks again, Kurt.
Kurt, Did you ever get a PN on this? Or does anyone else know it? I went to the above company and its not listed. I need one also while I have the drive shafts unhooked. Thanks Kevin
