mklotz70 Posted July 12, 2010 Report Share Posted July 12, 2010 My wife's 521 clutch slave decided it was about time for some attention. I decided to go with a 620 slave since they had it in stock at Knecht's. It wasn't until I was already into the project, that I realized the slave didn't have the holder for the spring. I could have gotten a different one, but after burrito's recent challenge with his clutch slave, I decided to go this route. It allows for more torsion bar clearance on the 320s if you have a floor shift trans. My column shift required a mounting adapter...but that's a different thread :) Here's some pics on the spring holder and a few vids on how to adjust the clutch slave. I would prefer to have the bleeder valve mounted in the top hole, but you can see the machined recess for the copper washer to seat on...so the hose goes in the top hole. The bracket I used had an existing hole, so I used a washer to make sure it could slide over the hex part of the bleeder valve. Hope this helps. Quote Link to comment
mklotz70 Posted July 12, 2010 Author Report Share Posted July 12, 2010 I forgot to mention....if you go with the 620 slave cyl, it will be metric threads. I already had a metric nut on the end of the hard line, so I used the hose in the previos pic. If you are working on a 521 with SAE threads, I'm pretty sure this will be the hose you need. Both hoses went into the m/c, it was the end connecting to the hardline that was different. I may have it backwards....it's been several weeks since I did this. Just remember to double check that your hard line goes into the hose you're using....if not, try the other hose. I bought and took home both, then returned the one that didn't fit :) Quote Link to comment
laotsu Posted July 12, 2010 Report Share Posted July 12, 2010 nice to know that the underside of your 521 is just as oily and rusty as mine. Now I don't feel like such a slob. :mellow: Quote Link to comment
Pacific coast Datsun Posted July 13, 2010 Report Share Posted July 13, 2010 Once again nice fab skills Mike :cool: Quote Link to comment
burrito213 Posted July 13, 2010 Report Share Posted July 13, 2010 awsome information... how simple and complex this can be... Quote Link to comment
mklotz70 Posted July 13, 2010 Author Report Share Posted July 13, 2010 Glad you guys like it :) I've had disc brakes on that truck for over 7 years.....and it was a few before that since it's been cleaned..... :) It will get it's turn sooner or later :) Quote Link to comment
dat521gatherer Posted July 20, 2010 Report Share Posted July 20, 2010 thanks mike. i just adjusted mine the other day and was wondering about the slack. part of me said to leave a little room and the other part (the evil side) said make it snug. so i made it snug. and i've been thinking about it the whole time. now i will go put a 1/16 of slack in it. :rolleyes: Quote Link to comment
dat521gatherer Posted July 20, 2010 Report Share Posted July 20, 2010 dont know if the wheel cylinder hoses on my 521 are the same as my clutch slave hose but every time i've bought wheel cylinder hoses from shucks or rockauto the threads are wrong. i think the master catalog is wrong. Quote Link to comment
mklotz70 Posted July 20, 2010 Author Report Share Posted July 20, 2010 I wonder if someone put 620 cyls in your rig....or maybe they're selling you 620 hoses? Quote Link to comment
hang_510 Posted July 20, 2010 Report Share Posted July 20, 2010 RETURN SPRING be sure to use a spring w/sufficient tension. i didnt and it required a third adjusting, after i 'tuned' it ;) Quote Link to comment
