'70dime Posted July 11, 2010 Report Share Posted July 11, 2010 I have a '70 510 and I decided it was time for some tunes for the first time since I've had the car. The problem I'm running into is where to mount the front speakers. I want to put them in the kick panel but not only is the existing hole to small but it I made it big enough there wouldn't be enough depth. I just want to know what others have done, or if they have any ideas for my car. any help would be greatly appreciated. Pierce Jones Quote Link to comment
datzenmike Posted July 11, 2010 Report Share Posted July 11, 2010 And there's the problem. The kick panels are the perfect spot but not deep enough. The door is then the obvious choice but I won't ever mount one there after seeing so many cars with ruined doors. Perhaps buying special thin speakers designed for this? I was lucky and they did fit my 620 kicks. I put a biscuit speaker on top of each side of the dash. Biscuits look like Oreo cookies... do they still make them? Anyway they only pass high frequency and the right and left bounce off the inner windshield and into the cab and provide great stereo imaging. If you only have the 4" in the kicks a passenger's legs kind of block this. Quote Link to comment
'70dime Posted July 11, 2010 Author Report Share Posted July 11, 2010 Alright, I'll look into those but I'm trying to do this on the cheap. I think I might try to make some fiberglass kicks that poke out a bit. Quote Link to comment
Braden Posted July 11, 2010 Report Share Posted July 11, 2010 when i installed speakers in my 620 i just used some 3/8' plexi glass and cut spacers out with a hole cutting tool and that gave me the extra clearance to fit the magnet in, if i were you i would sand down some of that rust, self etching prime it and them paint it semi gloss black so that when they look down at your sweet new speakers they see fresh paint. Quote Link to comment
thisismatt Posted July 11, 2010 Report Share Posted July 11, 2010 Fiberglass kick panels/pods. Quote Link to comment
datzenmike Posted July 11, 2010 Report Share Posted July 11, 2010 I found I was always kicking the grill off. Quote Link to comment
'70dime Posted July 11, 2010 Author Report Share Posted July 11, 2010 Braden- I will be sure to do that. I also have some material to make new kick panels. I think I will try fiberglass first, then use the plexiglass idea. Any ideas on what kind of wood to use when framing the fiberglass. Quote Link to comment
thisismatt Posted July 11, 2010 Report Share Posted July 11, 2010 I would do the speaker ring out of 3/4" MDF. The backing that will go up against the floor/kick panel...maybe 1/4" MDF. The home depot here sells quarter sheets of MDF, so that would be easy to pick up and work with. Quote Link to comment
'70dime Posted July 11, 2010 Author Report Share Posted July 11, 2010 Alright, I'll be sure to take pics and let you guys know how it goes. Quote Link to comment
fo0manchu Posted July 11, 2010 Report Share Posted July 11, 2010 put them in the air vents. Quote Link to comment
Spades Posted July 11, 2010 Report Share Posted July 11, 2010 wanna know the cheapest and easiest ways to install front speakers on a 510? either buy 3.5" speakers and put them in the air vents and run your air vents with some ducting to dump them under the dash, or remove the ducting completely, OR...put a 4" with a grill assembly in the kick panels. the hole in the kick panels is not large enough or deep enough, but there is a solution. Buy a piece of ABS plastic pipe the same diameter as the outer plastic of your speaker grill, and get creative. The other option is what I will be doing...buy a pair of 5.25" or 6.5" shallow mount speakers, and buy a 5.25" or 6.5" plastic spacer. these spacers can be purchased from almost any car stereo shop or online for about $10. They are usually 1" depth, but you can also buy 2 pairs, and stack them together. Use an epoxy to stick them together, sand them down on the outside, and paint them with krylon fusion to match your interior. MDF rings can be purchased from places like sonicelectronix, or you can build your own kick panels from a sheet of Medium Density Fiberboard, or if you are good with fiberglass, you can make some really trick enclosures. The possibilities are just about endless, it all depends on your level of creativity and how much cash you have available. Quote Link to comment
nullbound Posted July 12, 2010 Report Share Posted July 12, 2010 I used q-logic universal kick panel speaker mounts. See post 9 here for pics: http://forums.hybridz.org/index.php?/topic/74137-1971-datsun-510-goon/ If I had more time, I would have made my own out of fiberglass. These stick out a bit more than I want them to. But, they sound great. Quote Link to comment
Papi Chulo Posted July 12, 2010 Report Share Posted July 12, 2010 Remove gauges Install speakers ????? Profit Quote Link to comment
five10freak Posted July 12, 2010 Report Share Posted July 12, 2010 i made my kick panels then i covered them in vinyl Quote Link to comment
'70dime Posted July 12, 2010 Author Report Share Posted July 12, 2010 You guys are awesome, I have one million ideas now. I think a combination of 5in PVC (do they make that?) and fiberglass. and remake the kick panel with new material. What do you guys think? Quote Link to comment
Spades Posted July 12, 2010 Report Share Posted July 12, 2010 You guys are awesome, I have one million ideas now. I think a combination of 5in PVC (do they make that?) and fiberglass. and remake the kick panel with new material. What do you guys think? I know 4" ID ABS is common, maybe someone can correct me, but I think it goes from 4" to 6"... EDIT: don't forget to scuff the pipe up with very abrasive sand paper, otherwise the fiberglass resin won't bond at all to the PVC or ABS pipe. Quote Link to comment
'70dime Posted July 12, 2010 Author Report Share Posted July 12, 2010 Thanks all who have given me some input. Its not that I'm dead set on using these speakers but I already bought them I don't feel like sending them back to the seller on ebay. So if I don't mention your idea, don't feel bad. I'm just cheap. Pierce Jones Quote Link to comment
