Apollo77 Posted July 8, 2010 Report Share Posted July 8, 2010 whats your take? i have a Z22 block that i am building and plan on it being a daily driver. should i bore or not bore? and what pistons? i thought of flat top, but kinda lookin away from that now. been told if i could end up with alot of engine noise. thanks for all the help DV Quote Link to comment
hang_510 Posted July 8, 2010 Report Share Posted July 8, 2010 plans / goals for it? start w/the HG selections and then decide. (im thinking LZ here and may not be an issue!) there is no replacement for displacement. not sure how a bigger bore equates to increased noise? :? increased CR will cause issues if not accounted for now. Quote Link to comment
Z-train Posted July 8, 2010 Report Share Posted July 8, 2010 Z-22 with an L-20b head would be a good piece short of going the stroker route. Quote Link to comment
datzenmike Posted July 9, 2010 Report Share Posted July 9, 2010 whats your take? i have a Z22 block that i am building and plan on it being a daily driver. should i bore or not bore? and what pistons? i thought of flat top, but kinda lookin away from that now. been told if i could end up with alot of engine noise. thanks for all the help DV #1 Bore to 89mm. Install Z24 pistons on L20B rods. Use open chamber U67/W58 or equivalent 45cc open combustion chamber. Engine is 2288cc or 2.3Liter and has a manageable compression of 8.4 Same as #1 above but with P nut head 8.85 compression. Same as #1 above but with KA24E Pistons and 45cc open chamber head... 9.82 compression What's not to like with this set up? I like the #1 option as all the parts are easy to get and no one wants them. The head can be milled very slightly to raise the compression to just under 9. Any higher an there's pinging risk. Quote Link to comment
elmerfudpucker Posted July 9, 2010 Report Share Posted July 9, 2010 I stuck with the stock setup but had it bored out 20 over and no real noticible noise increase and went with all new guts. You can check out the build here:http://community.ratsun.net/topic/18069-2nd-720/ Kevin Sweeny is my mechanic that does all my engine work period. I do electrical not motors so I let him handle it. I and tossing the King Rats #1 idea around, I will get a picture of Kevin's face when I bring him all the parts and say "Here, can you build this for me?" :D Quote Link to comment
Apollo77 Posted July 9, 2010 Author Report Share Posted July 9, 2010 i believe that datzenmikes #1 is what i wanted to do. Z22 block with a L20B head, i just didnt know the pistons that i should be going with. thank you for the tips boys! i cant wait to see what i come out with :cool: DV Quote Link to comment
hang_510 Posted July 9, 2010 Report Share Posted July 9, 2010 Z-22 with an L-20b head would be a good piece short of going the stroker route. stroke is greater on the Z22 crank, and increased displacement over the L20 block. Z22 is a 'newer' block (mine was still cracked :rolleyes: ) original plan was a Z22 crank in the L20 block, for a real stroker ;) i used forged pistons w/a 1/2 dish, to create a quench area, and the CR is ~9.5:1 Quote Link to comment
elmerfudpucker Posted July 13, 2010 Report Share Posted July 13, 2010 Oh yea I forgot to mention, you heard the motor at canby, the exhaust has a small leak but other than that there wasnt no real noise increase that you heard right? Quote Link to comment
