Dimerforlife13 Posted June 16, 2010 Report Share Posted June 16, 2010 Are they the same as the 510's? I'm guessing not, what about the 720's? I have to go and pick my new KC up today but I need a radiator for it. Local yard has a 720 radiator.Any help is appreciated. -Brett 1 Quote Link to comment
zerow Posted June 16, 2010 Report Share Posted June 16, 2010 Are they the same as the 510's? I'm guessing not, what about the 720's? I have to go and pick my new KC up today but I need a radiator for it. Local yard has a 720 radiator.Any help is appreciated. -Brett What engine are you running? IIRC, the Z20/Z22 motor that would reside in the 720 has a different setup for the inlet and outlet, but I haven't been under the hood of a 720 for 15 years... L-Series radiators can be fitted much easier, so to answer your question a 510 radiator should work in your 620. 1 Quote Link to comment
]2eDeYe Posted June 16, 2010 Report Share Posted June 16, 2010 Interesting fact I discovered at Canby this year. Early 620's have the upper hose location on thopposite side of the later 620's. The 720 radiator I got has the upper in the same location as the early 620. The 720 radiaator is much wider than the 620 radiator. What truck are you picking up? 1 Quote Link to comment
Dimerforlife13 Posted June 16, 2010 Author Report Share Posted June 16, 2010 2eDeYe' date='16 June 2010 - 10:22 AM' timestamp='1276708937' post='315237']Interesting fact I discovered at Canby this year. Early 620's have the upper hose location on thopposite side of the later 620's. The 720 radiator I got has the upper in the same location as the early 620. The 720 radiaator is much wider than the 620 radiator. What truck are you picking up? I picked up a 78 KC, original paint, lowered, decent body, registered, needs interior. It needs a radiator to drive it home. I have one out of my 510 if I can just make it work for the hour drive home. I figure it I can get a bolt or 2 in, I can wire the rest up... 1 Quote Link to comment
Dimerforlife13 Posted June 16, 2010 Author Report Share Posted June 16, 2010 I picked up a 78 KC, original paint, lowered, decent body, registered, needs interior. It needs a radiator to drive it home. I have one out of my 510 if I can just make it work for the hour drive home. I figure it I can get a bolt or 2 in, I can wire the rest up... Picked it up for $500...she's got AC too 1 Quote Link to comment
]2eDeYe Posted June 16, 2010 Report Share Posted June 16, 2010 Nice looking truck, I'd give the 510 radiator a shot until you can find a correct late 620 radiator for it. They cool well. 1 Quote Link to comment
Dimerforlife13 Posted June 16, 2010 Author Report Share Posted June 16, 2010 2eDeYe' date='16 June 2010 - 11:18 AM' timestamp='1276712302' post='315265']Nice looking truck, I'd give the 510 radiator a shot until you can find a correct late 620 radiator for it. They cool well. All I need it to do is make it to my shop 1 hour away. Thanks for the advice Quote Link to comment
datzenmike Posted June 16, 2010 Report Share Posted June 16, 2010 Yup, the early 620 had the top inlet on the pass side then switched to the driver's side. The '80 720 had an L20B but I don't remember which side the top inlet is on. All other 720s were on the pass side and were similar to the L rad (thick double core) but slightly wider and don't fit the 620 very well. The later ('83 and up?) were very thin, and likely single core, taller and way wider. The 720 headlights are further apart than the 620 and it reminds me of a KA rad I have., Quote Link to comment
Dimerforlife13 Posted June 17, 2010 Author Report Share Posted June 17, 2010 Made it back without any issue. Was able to get one bolt in the radiator, and wired the rest real good. Worked great. Has a good size oil leak and the carb isn't in the greatest shape. I'm going to clean out the idle circuit and see if it will idle then. Damn thing drives down the road great for a $500 truck. No complaints here. Thank you all for the help. -Brett Quote Link to comment
Charlie69 Posted June 17, 2010 Report Share Posted June 17, 2010 I have a Brand new 620 3 core radiator in West Phoenix AZ. PM me if interested. Quote Link to comment
datzenmike Posted June 17, 2010 Report Share Posted June 17, 2010 ... the carb isn't in the greatest shape. I'm going to clean out the idle circuit and see if it will idle then. -Brett Check that the idle cut solenoid has 12 volt on the red wire to it when key is turned on. You should hear a click sound when the key is turned to on. If it's not working there will be no fuel getting to the idle circuit no matter what you do to the carb. Quote Link to comment
Dimerforlife13 Posted June 17, 2010 Author Report Share Posted June 17, 2010 Check that the idle cut solenoid has 12 volt on the red wire to it when key is turned on. You should hear a click sound when the key is turned to on. If it's not working there will be no fuel getting to the idle circuit no matter what you do to the carb. And once again, datzenmike is right. Idle cut solenoid-no 12 volts. Thanks Alot! -Brett Quote Link to comment
wildmaninid Posted June 19, 2010 Report Share Posted June 19, 2010 Is the a/c still intact and all there?? I have a 77 with a/c and the compressor is missing along with the lines...i found one but need some pictures of lines and such.......also in the a/c stuff mounted to the r/h inner fender is what looks to be an hour meter?? anyone know what this was for? Can't find any reference to it in the Factory manual..? Quote Link to comment
