foxarelly Posted June 7, 2010 Report Share Posted June 7, 2010 i think im in the market for some dual carbs!!! i dont know what i need or what im looking for. I have an L18 "i think" thats what the guy tells me and i dont know how to tell the difference! so any info at all would be great!!1 Quote Link to comment
skunk Posted June 7, 2010 Report Share Posted June 7, 2010 find your self some su carbs with a l manifold, Quote Link to comment
MicroMachinery Posted June 7, 2010 Report Share Posted June 7, 2010 I have an L18 "i think" thats what the guy tells me and i dont know how to tell the difference! so any info at all would be great!!1 In the casting at the top of the engine block(where the engine block and head meet), right below the 3rd/4th spark plug, there should be a raised area with a number stamped there. It should be L16, L18, or L20b, next to a 6-digit number. The 6-digit number is the production number. That's the best way to figure out exactly what you have for an engine. Quote Link to comment
nismo dr Posted June 7, 2010 Report Share Posted June 7, 2010 I think you should know what kind of motor you have before you start to modify it Quote Link to comment
foxarelly Posted June 7, 2010 Author Report Share Posted June 7, 2010 I think you should know what kind of motor you have before you start to modify it thats kinda what i was thinking!! Quote Link to comment
banzai510(hainz) Posted June 7, 2010 Report Share Posted June 7, 2010 http://www.v-performance.com/products/air_fuel.html#mikuni_carbs get a su manifold Quote Link to comment
DISLEXICDIME Posted June 7, 2010 Report Share Posted June 7, 2010 buying dual carbs and then tuning them cost's as much as doing a ka swap. Quote Link to comment
banzai510(hainz) Posted June 7, 2010 Report Share Posted June 7, 2010 takes me 45mins to bolt my carbs on a L motor. add more for modding the pedal to use a cable ,a day Quote Link to comment
DISLEXICDIME Posted June 7, 2010 Report Share Posted June 7, 2010 takes me 45mins to bolt my carbs on a L motor. add more for modding the pedal to use a cable ,a day yah but you know what you are doing ! and probably have a jet kit Quote Link to comment
I'm BLUE Posted June 7, 2010 Report Share Posted June 7, 2010 buying dual carbs and then tuning them cost's as much as doing a ka swap. How Much are you looking at in pricing ? :blink: Quote Link to comment
banzai510(hainz) Posted June 7, 2010 Report Share Posted June 7, 2010 yah but you know what you are doing ! and probably have a jet kit When I did this I didnt know what I was doing, I got lucky and and it runs great, No rejetting!!!!!!!! other on herehave had alot of proplems. esp webers. never can figure out those jets numbering sytems Quote Link to comment
DISLEXICDIME Posted June 8, 2010 Report Share Posted June 8, 2010 How Much are you looking at in pricing ? :blink: 1000 for new carbs and manifold 100 for main and air corrector jets 100 for re curving your distributor 50 for air horns 80 for air cleaners 40 on a synchrometer 10 for a cable set up from the j yard 200-500 single cam and trans with harness and ecu if your thrifty 50 on a ebay header 30 cut stock trans mount wled in a piece of squar tubing and use a gm mount 100 shorten drive line. 50.00 on wire and but connectors and zip ties 100 battery relocate to trunk 100 walbro fuel pump 50 on fuel line 100 miscellaneous 250 on sway bar 100 on flipping cross member ok maybe a ka is a 100 or 200 more but fuel injection is worth it lol yah but you know what you are doing ! and probably have a jet kit When I did this I didnt know what I was doing, I got lucky and and it runs great, No rejetting!!!!!!!! other on herehave had alot of proplems. esp webers. never can figure out those jets numbering sytems yah i sold my 45 once i realized how much it would cost to really get them tuned right. Quote Link to comment
foxarelly Posted June 8, 2010 Author Report Share Posted June 8, 2010 damn maybe ill go turbo!!! Quote Link to comment
banzai510(hainz) Posted June 8, 2010 Report Share Posted June 8, 2010 Dave on here spent $700 to get his webers dcoes tuned and still was never perfect ,so I did get lucky, if one can do it ,a KA or KA turbo car is the way to go.POWER reliablity is there also once done For simplicity and fixability on the side of the road. L motor!!!!! Quote Link to comment
