pl521sss Posted December 4, 2007 Report Share Posted December 4, 2007 Turn signal indicator are lit when I have the running or headlights on. Turn signals and hazard lights works. But on my dash, both indicator stays lit. What should I check to remedy this issue? Quote Link to comment
datsunaholic Posted December 4, 2007 Report Share Posted December 4, 2007 Corrosion in the bulb sockets, or wrong bulb types. Quote Link to comment
pl521sss Posted December 4, 2007 Author Report Share Posted December 4, 2007 Corrosion in the bulb sockets, or wrong bulb types. bulb sockets have some corrosion, will try to clean it up. How can does it send light up the indicator on the dash with out the blinkers engaged? Can flasher unit be the culprit also? Quote Link to comment
irsa76 Posted December 4, 2007 Report Share Posted December 4, 2007 Check the grounds and make sure the wires aren't damaged/shorting out on each other. Quote Link to comment
datsunaholic Posted December 4, 2007 Report Share Posted December 4, 2007 If the bulb socket is corroded, it can short the 2 contacts together. So, with the running lights on (which share the same bulbs with the turn sigs), it can feed all the turn signals, including the indicator (the indicators are on the same side of the switch as the signals). However, that would only light one side, not both indicators- unless you had 2 shorted sockets (one on each side). I missed the part about the signals working... they work perfectly normal, whether the running lights are on or off? And is this the 510 or 521? A short in a connector would work both ways, the signals would light up the running lights and vice versa. So, this brings up another possibility. The ground to the instrument cluster could be open. That would cause the dash lights to have no "natural" path to ground, so the electricity would find the next best route. Since the ground to the indicators is probably the same ground (so as such would also be "open"), it's backfeeding the indicators, and grounding through the turn signals themselves. But... a good indication of this would be the indicators wouldn't be at full intensity, AND the turn signals themselves would glow dimly (hard to tell, since the running lights would be on and outshine the dim signals). Me, I'd route a new ground to the cluster. I'd examine the cluster for burnt circuit traces (on the back), and check the existing grounds (especially the cluster-to-dash or body ground). Quote Link to comment
datzenmike Posted December 4, 2007 Report Share Posted December 4, 2007 That's easy. The running light or the turn signal light filament has blown and the loose end has jumped over and they are now 'welded' together. Trust me. Hey, you got to pull the bulbs to check them anyway, so look for one with the filament crossed over. Quote Link to comment
pl521sss Posted February 3, 2009 Author Report Share Posted February 3, 2009 (edited) old post and revisiting again. I removed all side markers and turn signal made sure it's the correct bulb. Sure enough front marker was rusted out and couldn't get the bulb removed. It was still working, never the less, removed with a new side marker housing. Replaced with all new bulbs from Sylvania (made in China). It sucks, blew 2 bulbs right away. Original Toshiba bulb worked better and still works. Imagine that. :eek: Replaced cluster gauge and checked for burnt circuit and reseated all bulbs. How many ground wires are there that are bolted to chassis behind the dash? Problem still persist. Turn signal indicator stays lit when runningheadlight is turn on. Is this more of a ground issue or....? That's easy. The running light or the turn signal light filament has blown and the loose end has jumped over and they are now 'welded' together. Trust me. Hey, you got to pull the bulbs to check them anyway, so look for one with the filament crossed over. If the bulb socket is corroded, it can short the 2 contacts together. So, with the running lights on (which share the same bulbs with the turn sigs), it can feed all the turn signals, including the indicator (the indicators are on the same side of the switch as the signals). However, that would only light one side, not both indicators- unless you had 2 shorted sockets (one on each side). I missed the part about the signals working... they work perfectly normal, whether the running lights are on or off? And is this the 510 or 521? A short in a connector would work both ways, the signals would light up the running lights and vice versa. So, this brings up another possibility. The ground to the instrument cluster could be open. That would cause the dash lights to have no "natural" path to ground, so the electricity would find the next best route. Since the ground to the indicators is probably the same ground (so as such would also be "open"), it's backfeeding the indicators, and grounding through the turn signals themselves. But... a good indication of this would be the indicators wouldn't be at full intensity, AND the turn signals themselves would glow dimly (hard to tell, since the running lights would be on and outshine the dim signals). Me, I'd route a new ground to the cluster. I'd examine the cluster for burnt circuit traces (on the back), and check the existing grounds (especially the cluster-to-dash or body ground). Edited February 3, 2009 by pl521sss Quote Link to comment
ppeters914 Posted February 3, 2009 Report Share Posted February 3, 2009 If that's the current condition of your fixture, all bets are off until you clean that puppy up! :eek: That just screams short-to-ground to me. Quote Link to comment
pl521sss Posted February 3, 2009 Author Report Share Posted February 3, 2009 If that's the current condition of your fixture, all bets are off until you clean that puppy up! :eek: That just screams short-to-ground to me. old post and revisiting again. I removed all side markers and turn signal made sure it's the correct bulb. Sure enough front marker was rusted out and couldn't get the bulb removed. It was still working, never the less, removed with a new side marker housing. Replaced with all new bulbs from Sylvania (made in China). It sucks, blew 2 bulbs right away. Original Toshiba bulb worked better and still works. Imagine that. :eek: Replaced cluster gauge and checked for burnt circuit and reseated all bulbs. How many ground wires are there that are bolted to chassis behind the dash? Problem still persist. Turn signal indicator stays lit when runningheadlight is turn on. Is this more of a ground issue or....? Quote Link to comment
banzai510(hainz) Posted February 4, 2009 Report Share Posted February 4, 2009 try bangin on the blinker can also!!!!!!! Quote Link to comment
pl521sss Posted February 6, 2009 Author Report Share Posted February 6, 2009 try bangin on the blinker can also!!!!!!! I took apart all marker light housing. They are pretty much like new condition, no rust with new bulbs. All marker lights up just fine Turn signal works When running lights are on, turn signal indicator (left and right) both light up without the turn signal being engaged. Just one of 3 electrical issues dealing with. Quote Link to comment
