hydroking68 Posted March 29, 2010 Report Share Posted March 29, 2010 so here i sit wanting to put these nice rims i got for a good price and thay dont fit so i want to change my 68 510 lug pattern from stock to 4x100 to get my 15in bbs that came of a bmw and i don't want to flar my car any one got any info thanks Quote Link to comment
Skib Posted March 29, 2010 Report Share Posted March 29, 2010 4x114 to 4x100 adapters Quote Link to comment
hydroking68 Posted March 29, 2010 Author Report Share Posted March 29, 2010 hay thanks i orderd them Quote Link to comment
banzai510(hainz) Posted March 29, 2010 Report Share Posted March 29, 2010 those adapters might make it a SPACER so hopfully it dont stick out so far.roll the fenders JLB motorsports sells ROTA RBs pretty cheap 465 shipped. Quote Link to comment
JDM510 Posted March 29, 2010 Report Share Posted March 29, 2010 sell your datsun and buy a honda.... done and done.... lol or buy rims that fit... not only will the added space of those spacers be hell on your wheel bearings... but they offten come loose and i have seen people loose wheels.. soo use loctite and say a prayer Quote Link to comment
hughdogz Posted March 29, 2010 Report Share Posted March 29, 2010 not only will the added space of those spacers be hell on your wheel bearings... but they offten come loose and i have seen people loose wheels.. soo use loctite and say a prayer I've heard both sides of the fence on this one. I agree that cheapo ebay ones you'd probably want to steer clear of. However, I found a place in San Bernadino that pretty much guarantees they won't break: http://www.motorsport-tech.com/ As long as you can get ~6 turns on the lugs for the adapters, you should be okay. Another good rule of thumb is 1.5 diameters of engagement the nut on the thread. Also, make sure the adapters are lug centric and not hub-centric. I'm having trouble understanding how adding an adapter to a positive offset wheel is going to cause more bearing load than the same width wheel when the backspacing and front-spacing are the same... Quote Link to comment
Grey_Matter Posted March 29, 2010 Report Share Posted March 29, 2010 goto www.ECSTuning.com...they are very high quality and cheaper than H&R (and better quality too imho) Quote Link to comment
///FiveOneOh Posted March 30, 2010 Report Share Posted March 30, 2010 1/2 the drift comunity uses bolt on spacers and their SR monsters and I've yet to see one fail. even the ebay ones. just make sure you get hubcentric ones or you can end up with a vibration that won;t go away. I'm still not a fan of them but as long as you torque them properly and check them now and then they should be fine. Quote Link to comment
datrod Posted March 30, 2010 Report Share Posted March 30, 2010 I love this. :lol: I've been making 4X114-4X100 spacer adapters for at least 12 years now. I have yet to have one fail. Or cause any excessive wear on anything. Yea mine are a little pricy but they work. As a matter of fact I'm making some as we speak. I'll try to get some action shots. Quote Link to comment
moparvwfreak Posted March 30, 2010 Report Share Posted March 30, 2010 i have adapter spacers onm my Passat. been tehre 3 years now and no issues. 22mm fromt and 25mm rear Quote Link to comment
