Dirttrack510 Posted March 25, 2010 Report Share Posted March 25, 2010 I am getting ready to start building a Hybrid Long Rod L20B motor or 2.1 liter/2100 or whatever you wanna call it. My question is this...Every time I read an article about building these Frankenmotors, The Parts list always says to use Z22E pistons that are +1mm oversize to get 88mm. When you try to buy pistons, the parts store doesn't sell them that way. They want to know .010, .020, .030 oversize etc. etc. etc. What Over bore do I need to ask for? Quote Link to comment
chiquapen Posted March 25, 2010 Report Share Posted March 25, 2010 I am getting ready to start building a Hybrid Long Rod L20B motor or 2.1 liter/2100 or whatever you wanna call it. My question is this...Every time I read an article about building these Frankenmotors, The Parts list always says to use Z22E pistons that are +1mm oversize to get 88mm. When you try to buy pistons, the parts store doesn't sell them that way. They want to know .010, .020, .030 oversize etc. etc. etc. What Over bore do I need to ask for? .040=1mm 1 Quote Link to comment
Dirttrack510 Posted March 25, 2010 Author Report Share Posted March 25, 2010 .040=1mm Thanks, I looked all over the net and couldn't find an answer. I knew I could count on a fellow Ratsun member to help me out. :thumbup: 1 Quote Link to comment
datzenmike Posted March 25, 2010 Report Share Posted March 25, 2010 I couldn't find where it says a 1mm oversize Z22E piston. If you are using a Z22 block just check the bore for wear. If within spec you can just hone and re-use the stock pistons. If too worn, just order the next oversize 0.010" 0.020" whatever. If you are using an L20B simply overbore to fit the stock 87mm Z22 pistons. This is way cheaper than buying oversize pistons. 0.010" or even 0.394" (1mm) isn't going to make hardly any difference in engine size. In any case, never bore to what ever oversize the pistons are that you choose. The pistons should be supplied to the shop doing the boring. NO piston is exactly 87mm. They are mass produced and fall just below and above that amount. This is the same with the blocks at the factory, no bore is exactly the correct amount. During assembly a slightly large piston is mated to a slightly oversize bore. The shop doing the bore job will measure the piston and bore to fit. At least a good shop will. Quote Link to comment
HRH Posted March 25, 2010 Report Share Posted March 25, 2010 Just like bearings, some are in mm, some are in thousandths. 25.4 mm = 1 inch. So, logically, .25mm = .010, .020 =.50mm, and you can figure it out from then on. Quote Link to comment
hang_510 Posted March 25, 2010 Report Share Posted March 25, 2010 what HG are you using? The shop doing the bore job will measure the piston and bore to fit. At least a good shop will. :thumbup: bring the new pistons w/the block to the shop. Z22s has the same rod length as the L20; Z22e do not. Quote Link to comment
datzenmike Posted March 26, 2010 Report Share Posted March 26, 2010 Z22e has the same wrist pin height as the L20; Z22s do not. Want to take another run at that Brian? Quote Link to comment
hang_510 Posted March 26, 2010 Report Share Posted March 26, 2010 Want to take another run at that Brian? fine! <_< :unsure: rod length :blink: (fixed) check pin height on the pistons! Quote Link to comment
chiquapen Posted March 26, 2010 Report Share Posted March 26, 2010 Thanks, I looked all over the net and couldn't find an answer. I knew I could count on a fellow Ratsun member to help me out. :thumbup: u're welcome!!! :thumbup: 1 Quote Link to comment
datzenmike Posted March 26, 2010 Report Share Posted March 26, 2010 :poke: lol just keeping you honest Brian. :lol: The Z22S (carb) engines were only used in the 720 truck and all had the exact same rod as the L20B motor. The Z22E (EFI) engines were only used in the '81-'82 200sx. However if you have the early '81 Z22E made between June and December of '81 then it will have the same rod length as the Z22S and the L20B. From January on they were switched to the longer 6" length Quote Link to comment
Datsun fan Posted March 31, 2010 Report Share Posted March 31, 2010 .040=1mm The new 'revolutionary' law of gravity :lol: Quote Link to comment
