dryheat Posted March 12, 2010 Report Share Posted March 12, 2010 I just replaced every moving part on my 71 Goon front end including some new strut cartridges and took it in for an alignment. Apparently the right front wheel was at -3 derees of caster and they were wondering if the car had ever been in an accident. I personally have seen no evidence of any crash repair in the passenger front. The temporary solution was to add spacers to the backside of the TC rod and push the LCA further back. This caused the wheel to be pushed rearward as well and put a serious amount of stress on the LCA bushing. I would estimate that the wheel has been pushed back a little over and inch causing some rubbing of the tire in right had turns. So I need some advice please ... Where / what can I measure to try and figure out what is causing this? Other than the top of the strut tower being pushed back what else could cause my caster to be off so far? Thank you for any and all assistance / advise. Quote Link to comment
hang_510 Posted March 12, 2010 Report Share Posted March 12, 2010 what else could cause my caster to be off so far? that temp solution is scary if it breaks... struts installed rotated at the top ? using camber plates? the type w/caster built in? adj TC rods to correct & adjust. Quote Link to comment
Bleach Posted March 12, 2010 Report Share Posted March 12, 2010 My guess would be that your steering rack and/or front end is not square. That's basically what the shop was asking you. You can fake it by switching to coilovers. Adjustable rods and then Camber plates from Techno Toy Tuning. The plates can be angled too so that they add caster and camber at top... if you want. (45 deg) Quote Link to comment
benzo Posted March 12, 2010 Report Share Posted March 12, 2010 have you checked the lower control arms for if they are tweaked? also did you put back the strut housings back in the way they came out? Quote Link to comment
dryheat Posted March 12, 2010 Author Report Share Posted March 12, 2010 that temp solution is scary if it breaks... I agree ... which is why I am so concerned right now. using camber plates? the type w/caster built in? No camber/caster plates involved ... just the stock mounting hardware. struts installed rotated at the top ? I've never done struts before so please 'splain Lucy. Remember that I'm old and not too bright so use small words and if possible some pictures too! Quote Link to comment
hang_510 Posted March 15, 2010 Report Share Posted March 15, 2010 IF the struts were not removed, then its not the solution. if they were, then they need to go back in, in the original orientation. i had this done on an ol GF's RX7. end of story... the shop that did it, the shop manger was fired for being 'wrong' and calling us names, implying that we did something wrong after the work was completed. Quote Link to comment
INDY510 Posted March 15, 2010 Report Share Posted March 15, 2010 I am worried now...... My 710 struts did not line up right so I turned the top hat half a turn,,, ,, but now it looks like one side has more camber than the other side..... I have only driven it a couple miles, and everything feels fine,,,,, ,, How do you know "the right way" to line up the top hats?............. I think there are only 3 possible ways..... and only one right way.... Each side has a different wrong way....... one has camber in......... the other has caster back........ :( Figures...... if there is a 1 in 3 chance of getting something right,,,,, I will achieve 2 of the wrong ways....... FUCK :blush: Quote Link to comment
dryheat Posted March 16, 2010 Author Report Share Posted March 16, 2010 IF the struts were not removed, then its not the solution. Thanks Brian .. the struts were removed and I did not mark the orientation of the top hats so I'll pull them back out and try to figure it out. I appreciate the help. Since there are two extra holes in the top hat I will "assume" they have something to do with the orientation. If not I only have two positions left to try. Quote Link to comment
dryheat Posted March 17, 2010 Author Report Share Posted March 17, 2010 No joy ... I put the struts in their original location and it made no difference ... still have the same -3 caster. More research and measuring in my future. Quote Link to comment
thisismatt Posted March 17, 2010 Report Share Posted March 17, 2010 You had -3 degrees of caster and they pushed the wheel back, giving you more negative caster? Post makes no sense Quote Link to comment
D52E Posted March 17, 2010 Report Share Posted March 17, 2010 Yeah, I was thinking the same thing. Adding spacers would make the caster more negative... Quote Link to comment
dryheat Posted March 17, 2010 Author Report Share Posted March 17, 2010 I've never done struts before so please 'splain Lucy. Remember that I'm old and not too bright so use small words and if possible some pictures too! I guess my +/- was off. I found an indication that the right front strut may have had some repair work done. I will just remove the spacers and have the alignment shop make the car drive straight as possible and not eat tires and leave it at that. Thanks for everyones help. Quote Link to comment
thisismatt Posted March 18, 2010 Report Share Posted March 18, 2010 I guess my +/- was off. I found an indication that the right front strut may have had some repair work done. I will just remove the spacers and have the alignment shop make the car drive straight as possible and not eat tires and leave it at that. Thanks for everyones help. Post some pictures. Maybe you should replace the strut(s)? Quote Link to comment
