Datsun fan Posted February 15, 2010 Report Posted February 15, 2010 I just want to know the right specs of the diff oil needed for '77 MAZDA truck :rolleyes: Quote
I'm BLUE Posted February 15, 2010 Report Posted February 15, 2010 I just want to know the right specs of the diff oil needed for '77 MAZDA truck :rolleyes: What model , engine size , transmission please ? Thank you ! DTP Quote
Mini-L320 Posted February 15, 2010 Report Posted February 15, 2010 Im pretty sure that it uses the same as the Rx7. You do have the stock Rotary in it I'm assuming. but seeing since this is a truck it could use a bit more oil, rear end is slight bigger, I could be wrong. Best bet is to find a cheap Manual for it on ebay, I just bought one for my datsun 210 and only cost me $10 shipped. Quote
Datsun fan Posted February 15, 2010 Author Report Posted February 15, 2010 1600 cc engine, 4 speed manual Quote
Mini-L320 Posted February 15, 2010 Report Posted February 15, 2010 Its not a Rotary Truck? wow. Quote
Farmer Joe Posted February 22, 2010 Report Posted February 22, 2010 the lube for the rearend is prolly gonna be 80w90 gear oil. thats what my 77 luv took and im pretty sure that m 77 datsun book says 80w90 for a datsun. id just run a good brand of 80w90 gear oil and youll be good to go. Quote
Datsun fan Posted February 22, 2010 Author Report Posted February 22, 2010 Datzenmike wrote something about GL 4 and GL 5 and anti-scuff and brass or copper seals are fucked up by some kind of lube , I'm just cautious about that . Anything to make it clear ???? :cool: Quote
datzenmike Posted February 23, 2010 Report Posted February 23, 2010 Datzenmike wrote something about GL 4 and GL 5 and anti-scuff and brass or copper seals are fucked up by some kind of lube , I'm just cautious about that . Anything to make it clear ???? :cool: There is no brass or copper in the differential so use GL-5 80 W 90 or a good synthetic for rear ends. GL-4 contains less sulphur and is more tranny friendly. Nissan recommends GL-4 for trannys and GL-5 for rear ends. I think many new trannys are different and can use the GL-5 and the newer younger mechanics don't remember the need to protect the brass in the older transmissions. I've heard them tell people that GL-5 is better, and it is but also it's not compatible with brass. It's a slow process (corrosion) your tranny won't disintergrate if you use it. But it will attack the brass/copper over time. 1 Quote
datsunaholic Posted February 23, 2010 Report Posted February 23, 2010 Basically if you have brass or bronze parts you need a yellow-metal safe gear oil, I don't know about Mazda diffs but as far as I can tell there aren't any yellow-metal parts in a Datsun rear end. Transmission, there are. And not all GL-4s are yellow metal safe, and some GL-5s are. When in doubt, read the label. Been big discussions of this on a lot of older-vehicle boards. 1 Quote
Datsun fan Posted February 23, 2010 Author Report Posted February 23, 2010 Thanx guys,Now the options I have are clear . :cool: Quote
