AZhitman Posted January 20, 2010 Report Share Posted January 20, 2010 I'm having a stroker motor built for my SSS WRL411 (2000cc). At present, the exhaust is tiny, and it routes out through the fenderwell (one of the necessities to shoehorn the bigger motor into the 411 chassis). Anyhow, I intended to cut / weld it so that the bend intrudes less into the wheelwell (because turning left with aftermarket wheels is damn near impossible, LOL). However, it's such a tiny pipe, I'm wondering if I'm gonna need more exhaust diameter with the stroker motor. Any feedback / ideas / help / advice? Quote Link to comment
FoxyRoadster Posted January 20, 2010 Report Share Posted January 20, 2010 sidepipe, you know you want to! lol Quote Link to comment
Guest kamakazi620 Posted January 20, 2010 Report Share Posted January 20, 2010 If it's gonna be a 2.0 liter like ya said I wouldn't run anything smaller than 2inch diameter pipe Quote Link to comment
ggzilla Posted January 20, 2010 Report Share Posted January 20, 2010 2 liter stock type, a 1.75 pipe is fine. 2" pipe for 100HP 2.25" for 150HP 2.5 for 200HP 1.5" pipe is definitely small for a performance 2-liter. Maybe custom headers will be needed. :cool: How did you punch out the R16 to 2 liters? Quote Link to comment
67411sss Posted January 20, 2010 Report Share Posted January 20, 2010 I had an exhaust shop cut about an inch off the end the exhaust manifold and weld on a larger 3 bolt flange (the factory join always leaks) i sold the car and never got to finish it but it looked like it was going to work really well. What about flatten the pipe slightly as it goes past the front wheel? will that effect the flow of the exhaust? Are you cutting the hole back towards the firewall? With cutting the end off the exhaust manifold, maybe having it cut on an angle back towards the firewall and opening up the exit hole in the guard might give you enough room to have the exhaust exit on the angle. Good luck, sounds like it will haul with an "r20" in it. Quote Link to comment
67411sss Posted January 20, 2010 Report Share Posted January 20, 2010 :cool: How did you punch out the R16 to 2 liters? By using a U20 crank. Quote Link to comment
AZhitman Posted January 21, 2010 Author Report Share Posted January 21, 2010 I know exhaust sizing (I also own a company that builds custom catbacks for S-chassis / B-chassis Nissans).... I'm more concerned with the 411-specific routing issues, like 67411 was talking about. If someone had a R16 header handy, I'd like to test-fit it to see if I could modify one to fit past the steering box / frame rail. BTW, she'll be .030 overbored with flat-top pistons as well. :) Quote Link to comment
ppeters914 Posted January 21, 2010 Report Share Posted January 21, 2010 :cool: How did you punch out the R16 to 2 liters? By using a U20 crank. ...or use a H20 crank. Which option did you do, Greg? For stroked R16's, visit 311s.org. The Stroker Poll thread has the majority of info: Stroker Poll thread on 311s.org Pete Quote Link to comment
bonvo Posted January 21, 2010 Report Share Posted January 21, 2010 what about flat pipe? and run it along the wheel well? like stock but closer to clear everything then have it dump out the side with no muffler Quote Link to comment
