Help with part #s
I am starting to go through our NOS stuff and i found a couple of websites that help with breaking down parts numbers. Some of the numbers don't come up in the search, for example 80600-44002 is a door lock, the keys and lock have 8800 stamped into them(i am including a pic of it) the closest i can narrow down is to a 1960-70 datsun through key codes. Does anyone know of a website that lists what model datsun the part # goes to, all i can get is brief description and price but not the model it fits.
Here are some pics so far.
620 tach
mystery lock
510 tail light lense
620 fender emblems
anyone know what this goes on
i have 6 of these but no part # anyone?
  • Replies 18
620 tach
mystery lock
620 fender emblems
620 tach .............................. 24855 B8000
1200 tach ............................ 24855 H1800
Lock... unknown, might not be Nissan?
Left rear 510 lens................. 26526 A0600
620 fender badge................. 63806 B5501
Head light.... shrug
Manifold gasket..................... Likely L16/18 not likely for an L20B as the U67 head didn't have manifold coolant holes. Would work on them though. Would not work on L20Bs from '78 and on.
The 1200 tachometer that looks like the one in the photo is 24855-H3400. 24855-H1000 is the older style with different colors.
620 dash and 1200 dash are same design, but with unique differences. I'm using a 620 tachometer in my 1200, bolts right in.
Yes, 24855-B8000 is 1976-1978. It superceeded the PN 24840-B6400 which was used pre-76.
You can make a quick, fairly accurate guess with the applied model code. Or just search google for the full part number I often find matches that way.
I don't know if this will help, but:
http://www.datman.co.uk/interp.htm
I have used this chart in some form or another for almost 8 years now. Dat Man is The Man!
Bang on ggzilla, I copied the wrong number down. Should have noticed the first 5 characters didn't match the first 5 for the 1200 tach. My bad an I corrected my text.
