BUCKWHEAT Posted January 5, 2010 Report Share Posted January 5, 2010 anybody know what i need to make the 2001 chevy rims work .I put them on and the bolt pattern is dead on but the studs dont stick out enough.Ihave a 1972 521 stock brakes. Quote Link to comment
Hyphy Posted January 5, 2010 Report Share Posted January 5, 2010 Its probly the hubs. Havent tried it myself on my 521 yet, But you may need to have the wheels hub opening enlarged so they fit all the way against the drums. Quote Link to comment
sdsurf Posted January 5, 2010 Report Share Posted January 5, 2010 look in FAQ or do a search there is a TON of info on this... Quote Link to comment
Pacific coast Datsun Posted January 5, 2010 Report Share Posted January 5, 2010 Di it the right way & be safe. Have the center holes on the rims bored out to 4 inches. Youll also need "conical" seat lug nuts. & there may be an issue getting the center caps to snap into place, the dust covers on the hubs may interfere.. Easy fix there,,remove dust covers or section a piece out & re-weld. Quote Link to comment
denveratsun Posted January 5, 2010 Report Share Posted January 5, 2010 Not to dissagree with the idea of getting it done right...at all....but in some cases it is possible to do it right and do it yourself. With tapered lugs the center bore is of less importance as far as it's precise machining goes. Check this link out...or search "Yukon" in the search bar... http://community.ratsun.net/topic/6460-yukon-rims/page__p__81814__hl__yukon__fromsearch__1entry81814 the offset might be totally different between the 01 and the 08 Yukon rims, but here is a good start anyway on answering your question Quote Link to comment
mklotz70 Posted January 6, 2010 Report Share Posted January 6, 2010 ...uummmm....if he's putting them on a 521 with drums, the center bore is not the issue....it's the dish in the drum. He'd need a 1/4" spacer to fill the void behind the rim and longer stud bolts. I'm getting old and hazy on a lot of this, but I'm pretty sure on this one :) Quote Link to comment
1lo620 Posted January 6, 2010 Report Share Posted January 6, 2010 Mr KLotz is correct, they will fit over the hubs, just havet o get spacers. Hit a machine shop and see if they could cut a set. My buddy did them for a set of Titans on a 521. Put on spacers, no issues Quote Link to comment
mklotz70 Posted January 6, 2010 Report Share Posted January 6, 2010 I cut the centers out of old drums....make great spacers! Quote Link to comment
denveratsun Posted January 7, 2010 Report Share Posted January 7, 2010 Nope...The pic in the link I put up shows 2008 Yukon rims bolted firmly to my stock drum brake 521 with only the described work having been performed...no spacers. Thats why I was saying that maybe the offset from 2001 to 2008 is different. Pics of the rims you intend to run would help this thread a lot. As we all know GM makes a few rims for their trucks...it could be one of several options. Now...having said that, the "normal" Chevy alloy rim from the 90s (and beyond?) would never even come close without spacers. Quote Link to comment
slam_dat_sun Posted January 7, 2010 Report Share Posted January 7, 2010 They look real nice on there Quote Link to comment
mklotz70 Posted January 7, 2010 Report Share Posted January 7, 2010 Those do look really nice on there!! The spacers weren't actually for spacing the rim out....more to fill the dish in the drum. The rim near the center doesn't quite seat to the drum at the lugs because it hit the higher area surrounding the mounting surface. Quote Link to comment
denveratsun Posted January 7, 2010 Report Share Posted January 7, 2010 Hey Buckwheat....we need some pics man! WTH? Klotz is right about the dish of the drum...we need to buy disk kits from him then it wouldn't matter:rolleyes: Mine just fit man...thats all I can say...I applied fresh paint 3 or 4 times and went through the mounting process multiple times to be sure. The inside rim circle is different than on many sets of rims I have seen GM make though... WE NEED PICS MAN!!!!!!!!!!! :blink: Quote Link to comment
kezark31 Posted January 8, 2010 Report Share Posted January 8, 2010 On my 71 521 with the tahoe's I ran a 5/16 rear space because they rubbes on the frame in the rear. the fronts fit fine as for the center caps. i cut a little off the spindle in the front and smashed the dust cap down then dremeled the center section out a litle bit(removed plastic from the back of the center cap)then the fit fine. As for the lug nut i had to get mine from scwabs they were the only one that had the correct should so the lug wouldnt pull through the wheel also for the the other guys that need to get wheels bore there it tut on you tube that shows how to do it safely with a router and but. they do a set of escalades and q45 wheels i belive Quote Link to comment
