410/411/520 headlight retaining ring screws
Once upon a time, M4 -.75 was commonly used. Seem to have disappeared after Oct '68.
Looking for at least 4 (will take more if ya got 'em) headlight retaining ring screws, size M4 -.75. They came on the 410, 411 and pre-Oct '68 520's. The latter 520's and everything else use a different screw, probably M4 - .70.
Thanks.
  • Replies 6
00998-51110 is a pan head screw. This is for the 1966-1967 520s.
20 cents each from your Nissan dealer
Are you looking for the original style rather than what Nissan currently sells?
if you still can't find any, i've got a 66 520 core support w/head light rings attached
I buy stainless steel sheet metal screws from Home Depot. They fit and look just fine. Assuming you mean the screws that hold the surround, not the screws used to align the headlights, which were SAE, not metric, on the 410 and 411 models.
  • 2 months later...
No, I mean the retaining ring screws.
520 #00513 80710 @ $0.35 dealer
Wrong screw. That's for the chrome trim to bucket/surround.
Bucket
Screw
Screw hole
Screw in hole
Screw holding retaining ring in hole
Sounds great. You coming to GG tomorrow? Or anyone else that has these?
