goes2fast Posted December 12, 2009 Report Share Posted December 12, 2009 I just decided it was time to tell you guys what I've done so far and post a couple of pics of the truck before I do much more, so you know where it started. I bought the truck in Phoenix to get a rust free truck to start with. Unfortunetly It had a lot more dents than the pics showed, but what the hell, dents are a lot easier to fix than rust. So far I have installed HID head lights, but I need to move the battery back a little, as it interfears with the back of the HID bulbs as they are a little longer. This causes the bulbs to cock at an angle which messes up the focus and aim of the lights. Also I have changed the 79 grill over to a 76, which I like the looks of better. I have started on the interior, replacing the chevy door lock on the drivers door to a correct Datsun one. Next will be to clean the insides of the doors to ready them for insulation and sound deadener, and install my power lock actuators. While the weather was too cold to work either outside or in my unheated garage, I cleaned up the front half of the console, and installed all my electronics. I have my stereo, door lock switch, and relays, and alarm system all in one module. This should make it very easy to service if a problem comes up. I will post pics of this as soon as I get them taken. The one other thing I did befor taking pics was to paint the stock wheels satin black, as I couldn't tolerate the silver that someone thought was cool. Well I couldn't figure out how to import photos from my computer to this message, so they will have to wait. I guess I will list the parts I have collected so far to get my truck on it's way to being my daily driver. 1 Carb kit for stock hitachi (to get past smog check and get collector plate) 2 Better Dash pad and glove box. 3 New door seals 4 unscratched door windows for both sides 5 unbroken sun visors 6 Toyota dome light, fits the KC spot, and looks more modern 7 multi LED bulb for dome light 8 bright LED dash bulbs 9 water temp. sender 10 KA24DE and 5 speed (for after everything else is done and sorted out) 11 HID headlight conversion 12 New hood bumpers 13 new glass run channels 14 non sun cooked steering collum and ignition switch cover 15 power door lock actuators, relays, and rocker switch 16 K9 alarm system 17 JVC stereo with HD receiver 18 amp for subwoofer 19 leather shift boot for console 20 new rubber wiper boots 21 leather shift knob with original red, white, and blue Datsun emblem 22 valve stem caps with Datsun emblem 23 custom polished aluminum cross flow radiator 24 electric fan for radiator I'm sure there is more, but I can't remember right now. More later, when I figure out how to post pics.:):cool: Quote Link to comment
bonvo Posted December 12, 2009 Report Share Posted December 12, 2009 sound like a great start welcome to ratsun t post pics upload your pics to photbucket the copy and paste the code Quote Link to comment
goes2fast Posted December 13, 2009 Author Report Share Posted December 13, 2009 Bonvo, Thanks for the info.:):cool: Quote Link to comment
bonvo Posted December 13, 2009 Report Share Posted December 13, 2009 your welcome now pics please :P Quote Link to comment
chiquapen Posted December 13, 2009 Report Share Posted December 13, 2009 dang!!! still no pics?? i wanted to see too....:( Quote Link to comment
goes2fast Posted December 15, 2009 Author Report Share Posted December 15, 2009 OK, I'm going to attempt to post the pics now Big ouch on rt door! Not toooo bad. Changed the grill already, and installed HID headlights. Lots of cleaning and work to be done here. At least all the seats need is a good cleaning. Hitachi rebuilt and going back on. Freeway Blaster Horns and HID ballasts mounted. Front half of console ready to go back in. Alarm, and power door locks mounted under console. Closeup of Stereo and Door Lock Switch. Daylight shining through fiberglass where AZ sun cooked plastic til it turned to dust.:( The other fiberglass repair on the back half of console. Fiberglass repair ready for a little bondo, and a lot of sanding. That's it for now, have to finish putting the Hitachi back together, and straighten out the wiring at the rear. Then it will be drivable to go get smogged, then plates so I can drive it while working on the rest.:cool: 1 Quote Link to comment
bonvo Posted December 15, 2009 Report Share Posted December 15, 2009 not to bad do you have the horn button? if not i may be able to help Quote Link to comment
slam_dat_sun Posted December 15, 2009 Report Share Posted December 15, 2009 (edited) Man another guy that don't waste no time, looking good man . By chance did you find the truck on craigslist in Phoenix AZ ? It seems lie I saw that truck on cl . The one I am talking about had some butt ugly hubcaps on it, but they could have been taken off :lol: Edited December 15, 2009 by slam_dat_sun added to post Quote Link to comment
goes2fast Posted December 16, 2009 Author Report Share Posted December 16, 2009 Yes I have the horn button, have to repair the steering wheel before I put it back on. Also yes to phoenix and the ugly caps, want to buy them cheap? Today I re wired all the rear lights, cut down the front bump stops and screwed the torsion bars back to get the front dropped. I lubed everything up front while I was at it. I also adjusted the steering box to take the play out, now I have no slop in the steering, should drive a lot better. The last thing I did until it got too dark and cold was put most of the crap I had to take off to get the carb off back on. I misplaced one of the hoses, so I will start tomorrow off hunting for the hose, then if all goes well, I'll fire it up, adjust the carb and get it smoged, then a trip to the alignment shop. Then the body and interior begins.:blink::cool: Quote Link to comment
bonvo Posted December 16, 2009 Report Share Posted December 16, 2009 what hose i have every bitof smog equipment you can think of though you will probibly find yours in the morning :P Quote Link to comment
goes2fast Posted December 16, 2009 Author Report Share Posted December 16, 2009 It's the one that goes from a pipe on the side of the intake to the round valve that mounts at the rear of the intake. I can take a pic tomorrow if you don't kow what I mean. Thanks, Jim Quote Link to comment
slam_dat_sun Posted December 16, 2009 Report Share Posted December 16, 2009 Man I wish that I knew that you was willing to make the trip, There was a 98% mint condition kc 1979 620 it was white with working a/c, garaged all its life for $1250 obo . I would have bought it but I didn't have the money, The blue one you bought, wasn't it advertised for $900, how much did you pick it up for ? Quote Link to comment
goes2fast Posted December 16, 2009 Author Report Share Posted December 16, 2009 I wish I would have known about the white one too, I hate body work, but at least I don't have to fix rust, and the drive train is in great shape, the only thing it needed was the carb rebuilt. Once I get it smoged, and the collector plates, I can toss all that junk and put a webber on it til I'm ready to put the KADE in it. I paid $750 for it. The last one that was for sale around here that wasn't a rust bucket, but had no brakes, and had been sitting not running for a couple of years went for $1500, so I didn't think I would be able to do much better on my budget. 1 Quote Link to comment
goes2fast Posted December 20, 2009 Author Report Share Posted December 20, 2009 I found some 1/2 in. hose that didn't kink when bent around to the valve at the back if the intake, and fired it up with the freshly kitted Hitachi. My luck with Hitachi carbs hasn't changed, it still runs like crap. Time to step up to a webber, I wish it wasn't Christmas so I had some money to spare. Maybe there is a Hitachi expert here in CO that can help me? I'm dreaming again:lol::lol: I guess I'll just have to wait till after the hollidays, and start over.:(:P 1 Quote Link to comment
goes2fast Posted December 25, 2009 Author Report Share Posted December 25, 2009 Yesterday I said to hell with it, and took the weber off my 76 and put it on the 79, I'll just have to find a used weber conversion for the 76, so I can sell it. The KC runs great now, so hopefully next week I can get it smoged and plates on it. I also got my new tail lights with JDM lenses and installed them, now all lights are working and about 1/3 of them are converted to LEDs. Now the only parts that I need that are high on the priority list is the weber kit, and a radio delete plate. I almost forgot, I scored a set of hooker headers, new in the original box, so the exhaust will get up dated soon. 1 Quote Link to comment
slam_dat_sun Posted December 26, 2009 Report Share Posted December 26, 2009 I also got my new tail lights with JDM lenses and installed them Can you please post a picture of your tail lights? I am not sure that I know what JDN lenses look like . Quote Link to comment
Z-train Posted December 26, 2009 Report Share Posted December 26, 2009 Can you please post a picture of your tail lights? I am not sure that I know what JDN lenses look like . They just have a yellow lense for the turn signal. Quote Link to comment
slam_dat_sun Posted December 26, 2009 Report Share Posted December 26, 2009 They just have a yellow lense for the turn signal. Oh yeah I have saw a couple set of those, I prefer the solid red ones myself.... Quote Link to comment
goes2fast Posted December 26, 2009 Author Report Share Posted December 26, 2009 I like the amber turn lenses because on a lowered 620 they are so low that people tend to not see them. The Amber with real bright LED bulbs seem to get peoples attention better, plus you don't see many, and I like being different, as if being a grey beard driving a mini truck isn't different enough!:lol::lol::lol::cool: Quote Link to comment
goes2fast Posted January 2, 2010 Author Report Share Posted January 2, 2010 I had a set back and made some progress since my last post. Took my KC to get the smog test, tailpipe emissions were well below limits, but failed because no air pump. Went on a boneyard crawl, and found a KC that was mostly intact. I scored the whole air pump system except one hose was shot. also got sear rails I need, air conditioning vents and ducts, the rear section of the console, and the elusive passenger door I have been looking for. Now if I can find a dash face and that air pump hose, I'll be in great shape, and on the way to at least have a drveable truck while I work on the rest of it. Quote Link to comment
BEEBANI Posted January 2, 2010 Report Share Posted January 2, 2010 Looks good Jim! Quote Link to comment
goes2fast Posted January 2, 2010 Author Report Share Posted January 2, 2010 Looks good Jim! Thanks Jason, What's new with you? B) :) Quote Link to comment
chiquapen Posted January 9, 2010 Report Share Posted January 9, 2010 cool. i found your pics. nice kc. i had to give ya a plus one on this thread. 1 Quote Link to comment
goes2fast Posted January 12, 2010 Author Report Share Posted January 12, 2010 Thanks, I just wish I was making more progress!:D Quote Link to comment
slam_dat_sun Posted January 12, 2010 Report Share Posted January 12, 2010 Hell I think you are making great progress :D Quote Link to comment
