fisch Posted October 26, 2007 Report Share Posted October 26, 2007 Looks niiice! I've been wanting to see a 2 tone paint job on a truck. Wish he had more pics. http://www.oldcartrader.com/ocdetail46197.htm Link to comment
datzenmike Posted October 26, 2007 Report Share Posted October 26, 2007 Very nice but not the price. Don't understand the 3.70 gears. The stock 4.88s would get 'into' the turbo way quicker. Even the 4.375s from an L16 would be better. Got the o/d 5spd to make up for it. The 521 has the lines for two tone. Not sure if the 620 would look right with it's lower line that arches over each wheel well. Link to comment
fisch Posted October 26, 2007 Author Report Share Posted October 26, 2007 I've started a discussion on turbo'd trucks in the trucks section if someone wants to comment on the notion! Link to comment
Bleach Posted October 26, 2007 Report Share Posted October 26, 2007 You generally want taller gears for a turbo car. They have far more midrange torque so you want to use that torque. But of course I see this generally on a 300-500hp turbo Z (vs only 150-250hp NA) An old L18 turbo (probably carbed) would be lucky to have 150 flywheel hp. 4.375 or 4.11 would be perfect. I think a 72 even came stock with an L16 and 4.375 4.88 is 1969 and older, right? :blink: the price looks very reasonable Link to comment
datzenmike Posted October 26, 2007 Report Share Posted October 26, 2007 It says a modle 1300 so assuming the J13 engine and those, plus I checked the year, and pretty sure they came with 4.88s. Yeah, for a larger more powerfull set up 3.70 would work better. For an L 18 ... let her scream! Link to comment
73super Posted October 26, 2007 Report Share Posted October 26, 2007 the price looks very reasonable I think the price is VERY reasonable when you consider the amount of work, time and effort.. not to mention parts, paint, etc. that went into this thing. Of course it's not a 620.. but to each his own. :D Link to comment
Bleach Posted October 26, 2007 Report Share Posted October 26, 2007 well, of course its not worth buying since its not a 620.... but that's a given. :D Link to comment
fisch Posted October 26, 2007 Author Report Share Posted October 26, 2007 Yup I would have caughed up this much cash for this. If it were on this side of the country when I was shopping. The only thing I could find in New England was the 521 I bought. Which I would easily have to spend that much $ on to get it up to the standards of the 521 in the listing. Hell what's the paint alone on that rig cost? Link to comment
73super Posted October 26, 2007 Report Share Posted October 26, 2007 Hell what's the paint alone on that rig cost? I paint my own, but when you add prep materials and then the actual primer and paint I'm usually into it for a little over $600. Now if I was to take it to somebody you could begin with $1200 and go up from there. Link to comment
dropt98chevy Posted November 29, 2007 Report Share Posted November 29, 2007 well, of course its not worth buying since its not a 620.... but that's a given.:D Whats the difference between a 520/521 and a 620? Link to comment
pope_face Posted November 29, 2007 Report Share Posted November 29, 2007 Er... two different generations of the truck... actually, even the 520 and the 521 had differences... Take a look in the picture thread in the "trucks" forum... you'll get an idea of everything from the 521's to 720's and even one or two 320's... Link to comment
dat521gatherer Posted November 29, 2007 Report Share Posted November 29, 2007 nice truck i'd pay $3000 if the interior and engine compartment are as nice as the body looks. i dont think you 620 lovers would pay $3000 for a mint 521 fresh out of the factory!! 620's suck, 521's rule.:fu: Link to comment
datzenmike Posted November 29, 2007 Report Share Posted November 29, 2007 Whats the difference between a 520/521 and a 620? The 520 had single headlights and the 521 had duals, I believe. They were both rather boxy to look at with squared corners but appealing, in a '510 El Camino' sort of way.:D:D:D In '72 1/2 the 620 was introduced and ran through '79, with probably the most beautifully curved body ever put on a Datsun or Nissa truck. And, NO, I'm not biased. Link to comment
datsunaholic Posted November 29, 2007 Report Share Posted November 29, 2007 The 520 had single headlights and the 521 had duals, I believe. They were both rather boxy to look at with squared corners My 520 would disagree with the single headlight claim... Only the '65-66 520 had singles. The '67-68 had duals. Link to comment
pope_face Posted November 29, 2007 Report Share Posted November 29, 2007 Ok, as far as I can tell, there are several differences between the 520's and the 521's... this is what I figure: First off, the 520 is the older body style, so to me it looks a little older overall... just a vibe about the body. Maybe more curves, maybe in different places, I don't know, but you can tell there's something different about it. Looking at the picture above, the 521's don't seem to have as much "lip" over the headlights/grille. The 521 grille is one horizontal strip at both the top and bottom, and three in the middle, with a bigger gap between the top and 2nd strips, and the 4th and bottom ones. The 521's also had a separate grille and headlight surrounds. There seems to be a bit more of a gap between the bottom of the grille and the bumper on the 521's, and they had two wide cut-outs between the grille and bumper, with the turn indicators set to either side of the cut-outs, under the headlights. The marker lights on the 521's were separate units on the side of the fender... plain reflectors in the early years, and actual lights in the later years. The 521's had the same stance, but the tops of the fenders were narrower and the hood was wider. The hood also had a long, thin recess running from the emblem back to the cowl, whereas the hood above has a larger, rectangular recess. I think that if you compare a stock 521 to a stock 520, the 521 looks a bit more aggressive... The 520 seems to look more tame in comparison, at least to me. Then again, both seem to look take next to a "Bulletside"... I still vote 521 though. Hmm... now that I compare the picture above to my truck, I can also see that the little "fins" on either side of the front fenders are different between the two models... on the one above, they continue straight forward and down until they intersect the body line at the edge of the hood and seem to sort of disappear. On the 521, the front of the fenders is smoother and doesn't have the same body line, so the fins continue down until an couple inches above the headlights, then curve in to create the front of the hood... Link to comment
dat521gatherer Posted November 29, 2007 Report Share Posted November 29, 2007 dholic nice 520. do you plan on painting those stock rims? that would really set that truck off. Link to comment
datsunaholic Posted November 29, 2007 Report Share Posted November 29, 2007 The stock rims are gone... gave 'em to Bleach. I have another set, but I ended up with a set of Slot Mags that I put on... only to realize they don't fit right. I need spacers (small, maybe 1/4") to set the wheels out so they don't hit the hub. Link to comment
Bleach Posted November 29, 2007 Report Share Posted November 29, 2007 those stock wheels are chillin' in my garage. I'm looking to do a 6-lug swap on the Fairlady Z so I can run 14" steel wheels... :D Link to comment
fisch Posted November 29, 2007 Author Report Share Posted November 29, 2007 those stock wheels are chillin' in my garage. I'm looking to do a 6-lug swap on the Fairlady Z so I can run 14" steel wheels... :D Now that would be interesting to see! Link to comment
dropt98chevy Posted November 29, 2007 Report Share Posted November 29, 2007 I wish I already had my other truck sold. So I can pick this up. I looking for a project but this would be a nice truck to drive around until i was ready to tear it apart. Plus its only about 20 minutes away. Link to comment
