Madness Posted November 29, 2009 Report Share Posted November 29, 2009 We have a 2000 cadillac deville 32v northstar in our shop right now and i cant figure out what the hell is wrong with it! It has 205,XXX miles on it. Its 1 of a fleet for a limo service so if we can get this one running there's a possibility we can get the whole fleet in here! Symptoms: Cranks but wont start Cranking with full throttle it wants to start There is a loud squeak while cranking Intake smells like fuel No codes concerning the problem (only chassis and body) Temp gauge at operating temp but engine is cold (Tell me if this is a problem) 40 psi at fuel rail So far i've come up with a list of things that could be wrong. Fuel Pressure Regulator (No fuel in the vacuum line) Coolant Temp Sensor (Major problem for other vehicles) Bad Coils I do not know how to check for spark on this vehicle. Its coil on plug. I did pull the spark plugs and they look like they have never been changed (AC Delco) This might be a bit of a stretch for you guys (It is for me) but maybe, just maybe. Quote Link to comment
sssr20det510 Posted November 29, 2009 Report Share Posted November 29, 2009 start with the basics, check fuel pressure, check spark just like any other car just pull out a coil pack put a spark plug in the end of it and ground it, crank engine. Quote Link to comment
72240z Posted November 29, 2009 Report Share Posted November 29, 2009 40psi is max prime? Does it fall when cranking? Does it fall over time? If so how much. Does it want to start more so with starter fluid? The field way to check spark on a coil is to just pull out the coil and stick a plug in there, if it fires you have spark. You can arc out a screw driver in there too. It's the coolant temp gauge reading wrong and not the HTS correct? Quote Link to comment
slam_dat_sun Posted November 29, 2009 Report Share Posted November 29, 2009 I know 2 things about caddy's 1st I have a super nice pair of caddy boxer shorts :lol: 2nd I built a silverado extended cab with an escalade front cap . That's all I got to say about that . Quote Link to comment
sssr20det510 Posted November 29, 2009 Report Share Posted November 29, 2009 key on engine off is 41-47 psi fuel pressure spec Quote Link to comment
sssr20det510 Posted November 29, 2009 Report Share Posted November 29, 2009 what codes were in there all of them chassie and body Quote Link to comment
72240z Posted November 29, 2009 Report Share Posted November 29, 2009 My all data says thats max prime, there is a difference. Max prime would mean you may need to turn the key more then once to reach said psi. It shouldn't fall more then 10psi in 10min from max psi and at 10psi it shouldn't fall more then 2 psi in 10 min. Quote Link to comment
Madness Posted November 29, 2009 Author Report Share Posted November 29, 2009 i've found that we're getting the propper fuel pressure at the rail. When its cranking it seems like its not getting spark but if you full throttle it when your cranking it will sputter and almost start for about 5 seconds and then its back to seeming like it doesn't have spark... ill test the coils and see what happens. The plugs are horrible so im guessing they never keep up on servicing their fleet. Quote Link to comment
sssr20det510 Posted November 29, 2009 Report Share Posted November 29, 2009 change them and check for spark Quote Link to comment
Madness Posted November 29, 2009 Author Report Share Posted November 29, 2009 ok yeah for sure getting spark.... that hurt like a son of a bitch. Strange thing though, i pulled the front bank of coil packs and now it wants to start without it being a full throttle. In fact it idled for a split second.... EDIT: It runs without the front bank of coil packs....... Quote Link to comment
72240z Posted November 29, 2009 Report Share Posted November 29, 2009 Way to ask then ignore lol GL with it..... Quote Link to comment
Madness Posted November 29, 2009 Author Report Share Posted November 29, 2009 (edited) Im really sorry man. I really didnt mean to. The digital gauge on the dash says its at operating temp (right in the middle) I didn't check the fuel pressure, another mechanic did who went home for the night but he ruled out Low fuel pressure. Edited November 29, 2009 by Madness Quote Link to comment
sssr20det510 Posted November 29, 2009 Report Share Posted November 29, 2009 ok did it come in running??? you said temp is in the middle so it was running??? does it have any theft codes they have problems with that causing no start? Quote Link to comment
BJW's FiveTen's Posted November 29, 2009 Report Share Posted November 29, 2009 Crank position sensor?? Or The Coolant temp sensor could be making it super rich and not wanting to start unless your at WOT, Like its flooding its self. Just my .02 Quote Link to comment
Madness Posted November 29, 2009 Author Report Share Posted November 29, 2009 came in on a tow truck. As far as i know, The security wont even let it crank if thats the problem. What is WOT? Way back i had a gti that had a bad temp sensor and it would make it run rich. I would have to floor it to get it started. Maybe the problem but on a much more severe scale... Quote Link to comment
Madness Posted November 29, 2009 Author Report Share Posted November 29, 2009 BUT there are no engine codes.... Quote Link to comment
purple Posted November 29, 2009 Report Share Posted November 29, 2009 Wide Open Throttle At first I was gonna ask if the exhuast was clogged, but the it runs when you removed parts. If the plugs were never changed then none of the other parts are. Check to see how long the packs are supposed to last, might just need a new set, aka a good ol' "tune-up". Quote Link to comment
sssr20det510 Posted November 29, 2009 Report Share Posted November 29, 2009 pull all codes write them down and post them, wot is wide open throttle, security systems on these can still crank just wont start, just because its not an engine code dosent mean its not relevant. Quote Link to comment
sssr20det510 Posted November 29, 2009 Report Share Posted November 29, 2009 look at data and see if you have signal from both cam sensors and crank sensor Quote Link to comment
J.C_620 Posted November 29, 2009 Report Share Posted November 29, 2009 if not the cam position sensor it has to be fuel pressure(can you hear the pump run when switch is turned on?) 40lbs is not enough and if the owners havent kept up the matience check fuel filter as it may be dirty and whle you have the fuel filter off check pressure there Quote Link to comment
Madness Posted November 29, 2009 Author Report Share Posted November 29, 2009 Powertrain Codes P1571 - Traction Control Torque Request Circuit Network Codes U1000 - Class 2 Communication Malfunction Chassis Codes C1277 - Requested Torque Signal Circuit Malfunction Body Codes B0429 - Temperature Control #3 Rear Circuit Range/Performance Quote Link to comment
J.C_620 Posted November 29, 2009 Report Share Posted November 29, 2009 sounds like the ecm is bad:eek: i hate the 32v northstar mainly because the starter is under the intake:lol: Quote Link to comment
steve g Posted November 29, 2009 Report Share Posted November 29, 2009 crank angle sensor maybe...... also try disconecting the mass airflow sensor plug..... if it runs unplugged then its sending out false readings that the ecu cant detect. When unplugged and running the fault code will suddenly pop up.... GM computers arent very smart. Ford had a similar issue in the 90s with 4.6s in the mustangs Quote Link to comment
sssr20det510 Posted November 29, 2009 Report Share Posted November 29, 2009 u1000 is a no communication with pcm Quote Link to comment
Madness Posted November 29, 2009 Author Report Share Posted November 29, 2009 .... this vehicle wouldn't run on E85 would it..... the intake has that corn alcohol smell to it.... :blink: Quote Link to comment
