fo0manchu Posted December 24, 2009 Report Share Posted December 24, 2009 yeah theres one on here. been under the knife for a while. cant recall the build thread. maybe someone can chime in? Oh yah, i remember reading on that awhile back. So is that thing running yet? That thing pretty much has a tube chasis, anything is possible when you do that. Looks like a fun ride if it gets all done though. Quote Link to comment
Foxx60 Posted December 28, 2009 Report Share Posted December 28, 2009 Any one think of an rb26dett awd in a 620, baisic 620 on skyline platform stretched or shortened thats what im thinking of doing. Anyone got engine measurements? Quote Link to comment
N0RCALDIME Posted March 6, 2010 Report Share Posted March 6, 2010 bringing up a dead thread here, but the aforementioned G54B-T swap in a 510 in is the works. (TOP SECRET) Quote Link to comment
DaBlist Posted July 16, 2012 Report Share Posted July 16, 2012 I know most swaps are about power but I have thought about a Suzuki G13 and 5spd trans from a Samurai for my B110/1200 coupe. These engines and trans are pretty small with aluminum block and case. Of course you could add a turbo later or a NA G16. These cars are so light aka light duty any real power you add requires adding weight in suspension, brake, & rearend up grades. I think with the 1200 focusing on a little more power and lighter weight would be the way to go. If rear power is wanted I'd start with a different chassis. Quote Link to comment
72240z Posted July 16, 2012 Report Share Posted July 16, 2012 Holy thread revival batman! Quote Link to comment
bananahamuck Posted July 16, 2012 Report Share Posted July 16, 2012 What he said^^^ lol But since you opened it ,,If your thinking Suzuki samurai trans , and better mileage per gallon,,there`s a guy in Oregon that makes an adapter kit to bolt an older VW diesel engine in a samurai ,, and the cost is very reasonable..Can`t remember company name but my friend used one and it included absolutely everything needed, for something like $550. somewhere in there.....You probably be able to drive around the earth twice on a tank of fuel.. :D I know most swaps are about power but I have thought about a Suzuki G13 and 5spd trans from a Samurai for my B110/1200 coupe. These engines and trans are pretty small with aluminum block and case. Of course you could add a turbo later or a NA G16. These cars are so light aka light duty any real power you add requires adding weight in suspension, brake, & rearend up grades. I think with the 1200 focusing on a little more power and lighter weight would be the way to go. If rear power is wanted I'd start with a different chassis. Quote Link to comment
ggzilla Posted July 16, 2012 Report Share Posted July 16, 2012 Suzuki G13B automotive engine in a 1200 Suzuki G13B Twin Cam 16V. Forged everything, aluminum everything. Tough as nails. 100hp @ 6500 RPM. Only no one ever finishes the swap because bigger engines keep calling. The 1200 is perfect for a large four cylinder like the 154hp KA24DE, 156hp 2.6 Astron 4G54, 187hp CA18DET, 202hp SR20DET. Quote Link to comment
DRIVEN Posted July 16, 2012 Author Report Share Posted July 16, 2012 Holy thread revival batman! No kidding. Since I started this thread my car has already had 2 swaps done to it and I'm collecting parts for a 3rd. Of all the realistic options mentioned so far, the VW diesel still intrigues me the most. I'm really surprised it hasn't been done yet. Maybe I'll start collecting those parts for swap #4 B) . 1 Quote Link to comment
Loren O Posted July 16, 2012 Report Share Posted July 16, 2012 I have an l20/28/z trans on my 70 goon now,but always planned on swapping im a vg30 someday. I've been trying to find out if my 280z trans will work wirt a lz22 swap until I can do the vg30 swap. can one of you answer this for me? Thanks! Quote Link to comment
Loren O Posted July 16, 2012 Report Share Posted July 16, 2012 Sorry about all the typo's i' using my cel,& I hate the touchscreen keyboard! Quote Link to comment
ggzilla Posted July 16, 2012 Report Share Posted July 16, 2012 Yes, if your LZ22 is using an L-block the 280Z transmission will bolt right up to it. Quote Link to comment
DaBlist Posted July 16, 2012 Report Share Posted July 16, 2012 "Holy thread revival batman!" Engine swap threads should never die! Unless it's about putting a cast iron V8 in a Datsun, those should never start. Quote Link to comment
Guest kamakazi620 Posted July 16, 2012 Report Share Posted July 16, 2012 "Holy thread revival batman!" Engine swap threads should never die! Unless it's about putting a cast iron V8 in a Datsun, those should never start. A chevy 4.3 v6 should be a good swap,mild build puts down 300hp Quote Link to comment
Dat Lurka Posted July 16, 2012 Report Share Posted July 16, 2012 I've always wanted to swap a GM 3800 Supercharged. Haven't sourced a rwd trans. Quote Link to comment
Dat Lurka Posted July 16, 2012 Report Share Posted July 16, 2012 A chevy 4.3 v6 should be a good swap,mild build puts down 300hp fuckmild Quote Link to comment
DRIVEN Posted July 16, 2012 Author Report Share Posted July 16, 2012 I've always wanted to swap a GM 3800 Supercharged. Haven't sourced a rwd trans. The 3800 uses the 60* bellhousing pattern. It was used in the mid '90s Camaro/Firebird so either a T5 or a 4L60E could be used. For the supercharged version the biggest problem is that the stock throttle body location would be inside the firewall. Using an elbow can fix that. The supercharger swap has been done on the RWD 3800 many times. There was a 510 build thread on the realm but I don't think it ever got finished. Looked like steering was going to be creative. I always thought the 3800 would be a great candidate for a 521/620 swap. Quote Link to comment
DaBlist Posted July 16, 2012 Report Share Posted July 16, 2012 4.3 - That would be awesome in something like a 810 goon. Quote Link to comment
ggzilla Posted July 16, 2012 Report Share Posted July 16, 2012 How about a Toyoda V6 in a 510? Those are great engines and OHC too. Quote Link to comment
Danfinny Posted July 17, 2012 Report Share Posted July 17, 2012 well since someone brought up the 3800 V6... check out what i just picked up Quote Link to comment
DRIVEN Posted July 17, 2012 Author Report Share Posted July 17, 2012 Reversed exhaust manifolds? I'd love some pics of the underside. Quote Link to comment
Danfinny Posted July 17, 2012 Report Share Posted July 17, 2012 yup and a hell of a job tucking them in, but a torque monster this thing is... i will try and get it on the lift this weekend. Quote Link to comment
DRIVEN Posted July 17, 2012 Author Report Share Posted July 17, 2012 That engine was on my short list. Glad to see that one was actually completed. I'd bet it walks away from a VG without breaking a sweat. Quote Link to comment
Danfinny Posted July 17, 2012 Report Share Posted July 17, 2012 would like to find out. lights 1-3 up easy.... it has some issues i need to take care of first... the suspension need work to say the least, its all over the road and really hard to drive in a straight line. got a high speed vibe thats either the drive shaft or a wheel bearing. it also still has an open diff so thats no good. also an annoying exhaust leak for the manifold. Quote Link to comment
DRIVEN Posted July 17, 2012 Author Report Share Posted July 17, 2012 Since the original intent of the thread was actually to archive and document swaps, I'll put up a few details for my current combo: GM 2.4 TwinCam. I used a 71series 5-speed and an adapter plate along with a mixture of GM/Datsun clutch parts. The crossmember needed to be shaved but not flipped or completely cut out. All the factory stands and rubber motor mounts were kept and I made my own block brackets. The stock center link needed to be dropped on the passenger side. I plan to eventually go to a front steer rack. A '98 Jetta radiator was used with a remote filler. A single electric fan keeps it cool with no problems. It appears that there is room to run a B210 booster but I haven't installed mine yet. No body mods were necessary. Was it a simple swap? Not too bad. Would I do it again? Probably. How does it perform? Similar to a KA. What would I do different? Well, there's never enough power. I'm currently collecting parts for build-up on my spare engine. With the correct combination of factory parts these have been documented at over 200hp. Quote Link to comment
