Bleach Posted September 30, 2009 Report Share Posted September 30, 2009 seriously how hard can it be to find the dip stick on an auto? 2 years of ownership and with a Factory service Manual and I can't find it. No way to fill this transmission or check the fluid level I guess. There are no pictures or references to it in the FSM either. Quote Link to comment
datsunaholic Posted September 30, 2009 Report Share Posted September 30, 2009 1) Why in Bob's name did you buy an automatic? 2) Having no dipstick nor provision for user maintenance isn't uncommon nowadays. It's already happened that there are cars on the market with no visable, owner-operable hood release. "Warning- do not open. No user serviceable parts inside." Quote Link to comment
izzo Posted September 30, 2009 Report Share Posted September 30, 2009 Pull the whole trans out. Find it, then youll know :D Nismo dr should know, since he is a nissan mechanic. this is what i was able to find, On all the newer Frontiers they take special trans fluid, nissan when AT put a black cap ontop of the sticks and put a 6mm bolt into them to keep people from mixing the fluid. Below is 2 pictures of the engine compartments. On both engines they are on the opposite side of the oil dipstick. Also on that black cap there should be a silver sticker on there say they take Matic J fluid. Look in the area that i have circled Quote Link to comment
Charlie69 Posted September 30, 2009 Report Share Posted September 30, 2009 Sealed from factory, like datsunholid said. Quote Link to comment
FATT STRIPES Posted September 30, 2009 Report Share Posted September 30, 2009 hahahaha, pull the breather off(base part too), it's under there on the paasenger side. you can get to it/see it w/o pulling the breather but it's more obvious once the breather base is out of the way Quote Link to comment
FATT STRIPES Posted September 30, 2009 Report Share Posted September 30, 2009 oh wait, i didnt ask what year and i dont see where u posted it. my last post would apply to the d22 4cyl Quote Link to comment
Bleach Posted September 30, 2009 Author Report Share Posted September 30, 2009 its a 2000. KA24DE 2wd auto Quote Link to comment
FATT STRIPES Posted September 30, 2009 Report Share Posted September 30, 2009 same as mine,then i was right in what i posted. happy hunting Quote Link to comment
SHADY280 Posted September 30, 2009 Report Share Posted September 30, 2009 if you go under the truck, there may be a level plug, kinda like a manual, except its a horizontal plug not vertical. it may be red, or a aluminum colored. i know the maximas are like that. Quote Link to comment
nismo dr Posted October 2, 2009 Report Share Posted October 2, 2009 pass side under air cleaner. Quote Link to comment
nismo dr Posted October 2, 2009 Report Share Posted October 2, 2009 old news matic J doesn't exist - Its matic S now:D 6mm is the bolt size the head is 10mm - regular dipstick after you unbolt it Pull the whole trans out. Find it, then youll know :D Nismo dr should know, since he is a nissan mechanic. this is what i was able to find, On all the newer Frontiers they take special trans fluid, nissan when AT put a black cap ontop of the sticks and put a 6mm bolt into them to keep people from mixing the fluid. Below is 2 pictures of the engine compartments. On both engines they are on the opposite side of the oil dipstick. Also on that black cap there should be a silver sticker on there say they take Matic J fluid. Look in the area that i have circled Quote Link to comment
Bleach Posted October 3, 2009 Author Report Share Posted October 3, 2009 pull the breather off(base part too), it's under there on the paasenger side. you can get to it/see it w/o pulling the breather but it's more obvious once the breather base is out of the way pass side under air cleaner. Thank you for the tip. You are right. Its different looking than I expected. There is even a clip to hold it in that is hard to move with one hand. The fluid looks full but is really thin and clear looking. Quote Link to comment
HRH Posted October 3, 2009 Report Share Posted October 3, 2009 At least there's something there. A lot of the newer vehicles literally don't have a fill plug. There's a snorkel apparatus that sticks up into the drain plug and injects the tranny fluid above that to then trickle down and fill the transmission. Ran into that at NAPA, gal called, said she drained the fluid, but can't put stuff back in. Told her to have it trailered down to the dealer or risk the trans being replaced. YET ANOTHER REASON NOT TO BUY A NEW VEHICLE! :D Quote Link to comment
Bleach Posted October 3, 2009 Author Report Share Posted October 3, 2009 My girlfriend's 2001 Civic (auto) has no pan or drain plug in the tranny. You have to put a hose down the dip stick and have the fluid sucked out and replaced that way. I didn't have the tools for that but she found a friend who did and got it done cheap. Quote Link to comment
