MicroMachinery Posted September 11, 2009 Report Share Posted September 11, 2009 I'm trying to collect parts to put a ka24de into my 71 510. I have opportunity to get a pedal from a 240sx, but if I don't have to have it, then there's no sense in buying it. I'm wondering if it's worth my time to go through the steps and modify my stock pedal(if I even need to?), or just get the 240sx pedal.. trying to do this while pinching my pennies, but I don't want to cut corners if I'm gonna hate myself later. Thanks Quote Link to comment
WagDatto Posted September 11, 2009 Report Share Posted September 11, 2009 I believe what I did with mine was re-use the stock pedal (for the life of me, I couldn't figure out HOW people were using 240sx... it's huge!!), but I had to cut/weld the "C-shaped clip" from a 240sx/300zx/whatever uses it pedal onto the stock pedal arm. Then you use the automatic throttle cable, and it should pop on the new pedal arm (be sure you know where to mount it!) and the TB. Quote Link to comment
bonvo Posted September 11, 2009 Report Share Posted September 11, 2009 anyone got a pic of a stock pedal? i know how i did mine i drilled the ball for the linkage out and ran an after market cable i dont know how different a 510 is from a 610 though Quote Link to comment
NorCalDime Posted September 11, 2009 Report Share Posted September 11, 2009 i used stock pedal and found a throttle cable from a newer mitsu mirage. it has this great plastic clip and ball that fits directly in the 510 pedal hole, it is the perfect length, and has a bracket on it that you can attach to your valve cover bolt so it is in the correct angle Quote Link to comment
Docsis510 Posted September 11, 2009 Report Share Posted September 11, 2009 I did the same as bonvo. I drilled the little linkage ball and installed a throttle stop I bought at the local auto parts. I took the cable from an auto 240. So far pedal is working good. Hope this helps. Quote Link to comment
MicroMachinery Posted September 11, 2009 Author Report Share Posted September 11, 2009 Sweet, thanks guys. I'll try the Mitsu Mirage fix. That sounds like a clean swap. Quote Link to comment
HRH Posted September 11, 2009 Report Share Posted September 11, 2009 1987 Mazda B2000 pickup. Works great! Can't even tell it's not factory. Quote Link to comment
71ka510 Posted September 11, 2009 Report Share Posted September 11, 2009 i just used the stock dime pedal and welded the 240 end to it.... and i used the 240 cable.... seems to work fine.... just need to fab a throttle stop up..... Quote Link to comment
nickel&dime Posted September 6, 2014 Report Share Posted September 6, 2014 I believe what I did with mine was re-use the stock pedal (for the life of me, I couldn't figure out HOW people were using 240sx... it's huge!!), but I had to cut/weld the "C-shaped clip" from a 240sx/300zx/whatever uses it pedal onto the stock pedal arm. Then you use the automatic throttle cable, and it should pop on the new pedal arm (be sure you know where to mount it!) and the TB. What year mirage? Quote Link to comment
datzenmike Posted September 6, 2014 Report Share Posted September 6, 2014 A quick check... http://community.ratsun.net/user/1882-wagdatto/ shows he was here last in May. He may not be around for many months so this thread will fall off the page unless you refresh it every day or so. I doubt he will be checking a 4 1/2 year old post. This is a waste of all our time. Why not send him a private message so it's waiting for him the next time he logs on? Quote Link to comment
nickel&dime Posted September 6, 2014 Report Share Posted September 6, 2014 A quick check... http://community.ratsun.net/user/1882-wagdatto/ shows he was here last in May. He may not be around for many months so this thread will fall off the page unless you refresh it every day or so. I doubt he will be checking a 4 1/2 year old post. This is a waste of all our time. Why not send him a private message so it's waiting for him the next time he logs on? What? Who's time I'm sure u got a lot of free time dude I'm sure he's not the only one who used this cable Quote Link to comment
datzenmike Posted September 6, 2014 Report Share Posted September 6, 2014 I'm saying if you want an answer from him, a PM is the easiest. I believe what I did with mine was re-use the stock pedal (for the life of me, I couldn't figure out HOW people were using 240sx... it's huge!!), but I had to cut/weld the "C-shaped clip" from a 240sx/300zx/whatever uses it pedal onto the stock pedal arm. Then you use the automatic throttle cable, and it should pop on the new pedal arm (be sure you know where to mount it!) and the TB.What year mirage? What mirage???? He doesn't even mention it....Did you mean to quote post #4??? this???... i used stock pedal and found a throttle cable from a newer mitsu mirage. it has this great plastic clip and ball that fits directly in the 510 pedal hole, it is the perfect length, and has a bracket on it that you can attach to your valve cover bolt so it is in the correct angle Again this is a 4 year old topic and NorCalDime was last here a month ago. Leave a PM for him.... http://community.ratsun.net/user/1248-norcaldime/ he may not see this. Also I ain't your 'dude'. I'm here to make it easier for all to pass info around. 3 Quote Link to comment
