Jester Posted August 18, 2009 Report Share Posted August 18, 2009 Well, I'm thinking of putting a lumpy cam in my truck. Stock right now. I'm running dual SU's, header, soon to have 2 1/4 exhaust, and 390 gears. Any thoughts? Advise? Cams for sale?? :D Quote Link to comment
banzai510(hainz) Posted August 18, 2009 Report Share Posted August 18, 2009 Iskidierian cams Webcamshafts.com new new or recondition rocker arms and if big can springs and lash pads. olddatsuns.com had the nismo parts #s listed 2.1/4 inch is too much. 2in is fine for a exhaust Quote Link to comment
datzenmike Posted August 18, 2009 Report Share Posted August 18, 2009 3.90 gears are too low. A lumpy cam will have poor manifold vacuum and drive ability. It's OK when revved up but piggish at low RPMs. Take offs will be a PITA with 3.90s. Stick with the stock 4.375s to help it off the line for in town driving. Quote Link to comment
yello620 Posted August 18, 2009 Report Share Posted August 18, 2009 3.90 gears are too low. A lumpy cam will have poor manifold vacuum and drive ability. It's OK when revved up but piggish at low RPMs. Take offs will be a PITA with 3.90s. Stick with the stock 4.375s to help it off the line for in town driving. :lol::lol: 3.90's are excellent, 4.375 suck. My 3.90's are not a problem at all around town. Second gear starts are still not a problem. And even when i hauled my last scrap load(980lbs.) it was not a problem at all. I don't miss my 4.375 gears even a little bit.:D Quote Link to comment
Guest kamakazi620 Posted August 18, 2009 Report Share Posted August 18, 2009 Hey Yello620, r u running a lumpy cam?? Quote Link to comment
banzai510(hainz) Posted August 18, 2009 Report Share Posted August 18, 2009 Cam Quote Link to comment
datzenmike Posted August 18, 2009 Report Share Posted August 18, 2009 hey yello620, r u running a lumpy cam?? x 2 Quote Link to comment
Jester Posted August 19, 2009 Author Report Share Posted August 19, 2009 Thanks for the feed back on this. I will be going to 390 gears though. Take offs right now suck! Hainz: do you have part #'s by chance? Beings this is my first overhead cam attempt, I don't know anything about lash pad setup. Were do I find some good reading on the subject? I am in the process of reading the "how to modidfy your Nissan/Datsun OHV engne". I'm at the cam section right now. Imagine that. :D Quote Link to comment
banzai510(hainz) Posted August 19, 2009 Report Share Posted August 19, 2009 like i said it was on olddatsuns.com http://olddatsuns.com/html/tech/partnum.htm but soem manufactures will have there own parts. I made a DVD on how to do the camlash inkpad ck which is simple. Maybe soembody can give you the full DVD . Its simple but cam cost money to do it right depending on size of cam. Cams work best with sidedraft carbs. keeping a DGV on there is still cutting the full power gain in half. Quote Link to comment
datzenmike Posted August 19, 2009 Report Share Posted August 19, 2009 Thanks for the feed back on this. I will be going to 390 gears though. Take offs right now suck! In what way do they suck? As I stated above, going down to 3.90 gears will make take offs a slight bit more difficult. I agree that on a stock truck this is a small amount, but on a heavily cammed motor this small amount becomes much bigger. I would do the motor and then decide on a gear change later after you have driven it. Quote Link to comment
Braden Posted August 19, 2009 Report Share Posted August 19, 2009 http://www.webcamshafts.com/index_blank.html?pages/vehicle_search.html take a look at this, you should get a set of mikunis or weber sidedrafts if you dont already have them, that will maximize your cam potential Quote Link to comment
Jester Posted August 20, 2009 Author Report Share Posted August 20, 2009 I'm running dual SU's, header....... I'm not thinking too big. Something around 270-280 duration and a lift as close to 460 as I can get. I stopped and talked to Steve at Z Thearopy today about cams. He has a guy that makes him a cam that is 270 dur. and 456 lift. Not sure of the lobe centers. He said it idles like stock and really lets the engine breath. He seems to think my carbs would LOVE this cam. Quote Link to comment
banzai510(hainz) Posted August 20, 2009 Report Share Posted August 20, 2009 get bigger. Ask him who makes these cams??????? Is it Delta out of tacoma? Quote Link to comment
Jester Posted August 21, 2009 Author Report Share Posted August 21, 2009 Thanks for the feed back on this. I will be going to 390 gears though. Take offs right now suck! In what way do they suck? As I stated above, going down to 3.90 gears will make take offs a slight bit more difficult. I agree that on a stock truck this is a small amount, but on a heavily cammed motor this small amount becomes much bigger. With the 437 gears, take offs are that of a dump truck. I'm grabbing for 2nd with in 20'. I don't think that 2nd gear starts are the answer. I'm basically putting the gears from my Hustler I gave to Beebani in my KC. Quote Link to comment
