herculesinwyoming Posted July 25, 2009 Report Share Posted July 25, 2009 has anyone added a inner wall on the bed to avoid denting the outside panels on the bed and tail gate. i think that will be one of my projects, after i get the body work done. 1 Quote Link to comment
Jester Posted July 26, 2009 Report Share Posted July 26, 2009 I was thinking of cutting the sides out of an old bed and useing them. If you cut right at the floor of the bed and along the top it should work awesome. I was thinking of useing some 1/2"X1/2" angle, butt the one toe up to the bed and tack it down. Then place the new "inner wall" against it and weld it down as well, trim the top to fit and it would look factory and you have double wall. Quote Link to comment
yello620 Posted July 26, 2009 Report Share Posted July 26, 2009 I was thinking of a mounting system that would allow me to make inner panels and they would be held in with Dzus fastners. Removeable inner panels would allow you to replace them if damaged and also allow bodywork to be done if you ever dented the outer panels. Quote Link to comment
MikeRL411 Posted July 26, 2009 Report Share Posted July 26, 2009 has anyone added a inner wall on the bed to avoid denting the outside panels on the bed and tail gate. i think that will be one of my projects, after i get the body work done. They are called bed liners and are usually made of ABS. Quote Link to comment
Jester Posted July 26, 2009 Report Share Posted July 26, 2009 They are called bed liners and are usually made of ABS. Those SUCK! Quote Link to comment
herculesinwyoming Posted July 27, 2009 Author Report Share Posted July 27, 2009 thanks for the input, im still a long waay from taking on that job, just thinking ahead right now Quote Link to comment
fastdadd Posted July 27, 2009 Report Share Posted July 27, 2009 you see those laying on the side of the freeway all the time Quote Link to comment
impala_631 Posted July 27, 2009 Report Share Posted July 27, 2009 i welded the sides in with16gauge,i havent done the tailgate yet,i will prolly use 20 gauge on it and roll some beads into it:) Quote Link to comment
kaoss Posted July 27, 2009 Report Share Posted July 27, 2009 Happens all of the time in the world of mini trucks, more for looks than what you are doing, but it's the same thing. Here is a thread with a ton of pics: http://www.streetsource.com/forum/topic.aspx?topic_id=108530&Page=1 Quote Link to comment
Jester Posted July 28, 2009 Report Share Posted July 28, 2009 As much as I would like to "finish" my truck bed, I don't think I would haul our bikes or fire wood in any of those. Quote Link to comment
ronnny Posted July 29, 2009 Report Share Posted July 29, 2009 I have not looked at a 5 or 620 in a time. My 720 has bolt in panels to make it a double wall. I think the 81 i have also has the holes to mount the wall but has not had double walls. If someone were close and they would work i would let them have em off my truck as mine is a work truck and will never make a nice truck condition but all but the tailgate piece is in good condition. Then the one of the 81 is for the tail gate. Quote Link to comment
BarryA Posted July 30, 2009 Report Share Posted July 30, 2009 that was at P&P in Rancho Cordova a few weeks ago - they were obviously made on a sheet metal shear and brake, and were painted to match the original olive green color of the truck. The sides are in three sections (one section above the wheel arch, one in front and one behind), plus a tailgate cover - the three sections were pop riveted together, the top edge was pop riveted to the upper edge of the bed, and the bottom edge was pop riveted to lengths of steel angle that were in turn pop riveted to the floor. I'm planning to bead-blast 'em down to bare metal, have them powder coated, and figure out how to mount them with Dzus fastners or stainless screws and rivnuts so they can be removed to clean behind them. I can lay the sections out, take photos and post them if anybody's interested...... Quote Link to comment
herculesinwyoming Posted July 31, 2009 Author Report Share Posted July 31, 2009 rock on.... nice work. Quote Link to comment
Loz Posted August 3, 2009 Report Share Posted August 3, 2009 fibreglass liners do a great job. but are they readily available for the 620? I was thinking about custom wood panelling for that old skool style, what do you think? might also ditch the checkerplated sides in favour of the "woodie" look... has this been done before? Quote Link to comment
Loz Posted August 3, 2009 Report Share Posted August 3, 2009 like this... but with more old skool flair... Quote Link to comment
