620 h190 rearend
  • Replies 7
if this can fit my wagon or at least the center section I may buy. I am in san francisco. Datzenmike I lost your info on this but can you refresh me if this can fit a wagon rear end with changing the inner gears on the axles. I am just wondering how it would be for my car as i have a 81 zx trans and long rod motor.
Edited by benzo
I bought this with the plan to use the gears in my wagon, but have since changed plans. I had offers just for the gears by wagon guys, and just for the axles by truck guys, but I don't plan on disassembly. I paid $75 for it a couple months ago, so anyone willing to pick up the whole thing gets the same deal.
Easy to take apart... drain, remove 4 X 17mm bolts on each side, cut brake line and yank the axels out (with drums on), remove the 12 X 12mm bolts from diff and pull it forward and out. Done this in a wrecking yard in 15 min including taking the drive shaft off.
